My new multichanel passive balanced pre-amp, battery/solar powerd, remotecontrol.
Old 5th October 2003, 10:00 PM   #1
Brian Guralnick is offline Brian Guralnick  Canada
Talking My new multichanel passive balanced pre-amp, battery/solar powerd, remotecontrol.
Almost done here, Gerbers should be going out tomorrow night. Canít wait!!!
Here are the architectural outlines, they will explain everything:
The attenuator module.
http://pages.infinit.net/helloftp/attenattenuator.png
The main processor & display / keypad PCB module.
http://pages.infinit.net/helloftp/attenprocessor.png
Here is the latest schematic of the attenuator. This should give you an idea of how the relay pot is wired.
http://pages.infinit.net/helloftp/attennewsmall.png
_______
Brian
Old 5th October 2003, 10:58 PM   #2
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
Hi Brian,
What is the attenuation range and steps on your design?
x-pro
Old 5th October 2003, 11:04 PM   #3
Listed in the first illustration in the top middle white box.
64 steps, 96Kohm, 48Kohm, 24Kohm, or 12Kohm, Constructed with 0.1%, or 0.5%(econo) resistors.
Current draw is listed in the bottom left hand corner box.
Module sizes are in the bottom right hand box.
If you are having problems seeing the fine text, it's Internet Explorer, you just need to un-zoom the image, or, download it & view with a picture viewer.
HELP!!! I notice some over-sized image posts do not make
Internet explorer crunch up the image, how do I do that???
_______
Brian
Old 5th October 2003, 11:21 PM   #4
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
if the picture is shrunk to fit, hold the cursor over it, and you will see icons appear, in the bottom right, click that icon, will goto full size.
Old 5th October 2003, 11:32 PM   #5
x-pro's Avatar
Hi again,
thanks for a quick reply, I didn' t read the text properly, sorry. There is stated clearly that the pots are linear. I did somewhat similar design couple of years ago, however I did use 7 relays per channel to give me 80 steps of 1 dB = 79 dB max attenuation + one more relay for a complete mute. My design had logarithmic curve for volume, otherwise it looks quite familiar .
Good luck!
x-pro
Old 5th October 2003, 11:43 PM   #6
Well, if you look at the software options on the processor page, I have a Volumetric, or Logarithmic software emulation.
However, that just makes a nicer volume curve with 24 steps, 24 sending the full 63 level on the relays. It does not simulate the surface resistance charactersist of a real logarithmic pot, or does it? Man, now my head is now spinning off in the wrong direction.
_______
Brian
Old 5th October 2003, 11:56 PM   #7
Originally posted by x-pro
Hi again,
Good luck!
x-pro
Thanks!
You should see the new relays I'm using, Omron G6KU-2G. They latch & they are the puniest thing i've ever seen. They are 10mmX6.5mmX5.2mm that's SMALLER than a DIP8. I even broke 1 open to see the distance on the contact switches, they are so short and small, you almost need a magnafying glass to get a good look at the contacts.
_______
Brian
Old 6th October 2003, 12:04 AM   #8
Here's a better view of the attenuator's schematic.
http://pages.infinit.net/helloftp/attennew.png
_______
Brian
Old 6th October 2003, 05:17 AM   #9
x-pro's Avatar
Hi Brian,
I did use exactly the same relays - G6K, thought not the latching type. These are not just small, they've got very good contacts quality as well and very low current consumption. Excellent choice . I did look at the larger schematics and have to say that the way you've organised the switching is quite different from what I did.
Cheers
x-pro
Old 6th October 2003, 07:21 AM   #10
fmak is offline fmak
[QUOTE]Originally posted by Brian Guralnick
[B]Here's a better view of the attenuator's schematic.
Brian
Looks very good. Are you making pcbs and building plans available and at how much pl?
What are the attentuator steps and the reistors types used?
My new multichanel passive balanced pre-amp, battery/solar powerd, remotecontrol.Hide this!Advertise here!
passive pre for UCD - balanced or SE??? ssmith Class D 0 29th May 2006 08:57 AM
Balanced DAC to unbalanced preamp (passive) conversions Dr.H Chip Amps 6 20th December 2004 05:56 AM
battery powered, balanced log attenuator pcb! Brian Guralnick Pass Labs 29 26th January 2004 11:30 PM
My new multichanel passive balanced pre-amp/solar powerd(tube mode)/remotecontrol. Brian Guralnick Tubes / Valves 0 5th October 2003 10:11 PM
Suggestions for a battery powered NON-balanced Mic Preamp? Phloodpants Analogue Source 4 23rd December 2002 05:22 PM
Copyright ©1999-2017 diyAudio
