Old 25th April 2012, 09:40 PM   #1
Redwingnine's Avatar
Default X 30.5 or X 150.5? (What would you buy?)
Recently, was able to obtain a pair of Cary Silver Oak Model One speakers. They are outstanding performers. The Cary's come equipped with 2 SEAS Excel Magnesium woofer/mid drivers per side, along with SEAS Excel soft dome tweeters. They are 88db@1 watt.
So, the question I had to answer was: Go with the XA 30.5 or X 150.5? After careful deliberation, decided to go with the XA 30.5. I’m pretty sure that they should have enough power for listening to most all types of music at moderate levels.
The question I have is as follows:
Are the XA 30.5 and X150.5 essentially the same amp, with different voltage rails and bias settings? The Threshold SA/3 and S300 were more or less the same (the late model with optical bias), and was able to successfully re-configure the S300 to SA/3.
Which amp would you pick, and why would you pick one over the other?
Old 25th April 2012, 09:59 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
considering that they're on wrong side of 90db/W/m (at least for me ) , in this case more is merrier
edit :
on second thought ........... just take cheaper one
both have plenty of oumph .......
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 25th April 2012, 10:51 PM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Paps is topnotch in designing modular stuff, within the same time frame.
The core of the X150.5 is the UGS4 module, the XA and INT models carry fifth and sixth iteration boards.
(fortunately, Da-da allows high-res. pictures for close-range-blind lasered idiots to cat-clone au maison-mansion)
Not so much,.......if it says "ZM" in the corner.
Old 25th April 2012, 11:17 PM   #4
edit :
Papa's website states that the XA 30.5 works with speakers above 87 db.
From the Cary spec sheet:
Dual Parallel Drive Magnesium mid-bass drivers, silk dome tweeter with neodymium magnet, air core heavy duty inductors, oil and foil capacitors, PHASE STABLE 3 r/d order crossover with 3.0 kHz crossover frequency.
So, I think the XA 30.5 would be OK. The price is the same for the X 150.5 and XA 30.5
Old 26th April 2012, 04:41 PM   #5
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
I have a XA30.5 driving a Quad ESL2805 (86dB 1W/m) and I'm very happy
Happiness is a warm soldering iron
Old 26th April 2012, 08:45 PM   #6
The one and only
Nelson Pass's Avatar
Old 27th April 2012, 11:20 PM   #7
Thank you, Mr Pass!
It goes with a couple of other Class A amps from Papa's past efforts:
1) Threshold 400A
2) Threshold SA/3
Old 5th May 2012, 04:46 PM   #8
Received the XA 30.5 the other day, and could not be happier with its performance. This is without question the finest sounding amp I’ve ever heard.
Many thanks, Papa. This is an outstanding performer. Now I have three generations of Class A amps (400A, SA/3, and XA 30.5).
Old 5th May 2012, 11:36 PM   #9
Zen Mod's Avatar
feel free to send gratitude check to me , too .
why leave Papa alone in this tricky situation ..........
(I'm really glad for ya )
Old 6th May 2012, 01:00 AM   #10
OK, you geet some gratitude as well
I had to save up for this a long time...but it was woth it.
FS/Trade Hammond 850G 150/600:150/600 Line Isolation/Hybrid Matching Transformers VictoriaGuy Swap Meet 0 3rd August 2011 09:29 PM
alpine pdx 2.150 or 4.150? cvedral Car Audio 2 2nd April 2010 10:58 PM
Van Alstine Mosfet 150 Modified Dynaco ST 150 Power Amp Scott Novak Swap Meet 1 7th August 2009 10:45 PM
before I buy a red wine signature 30... Ang Class D 8 21st January 2007 11:02 PM
If you had $150 -$200 to spend what Midrange/midbass would you buy? jainbaby Multi-Way 7 18th September 2003 07:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
