Will This Enclosure Work For F5/F6?
Old 23rd April 2012, 02:47 PM   #11
dantwomey is offline dantwomey  Canada
SiliconRay has responded that his heatsinks are,
300mm x 150mm x 50mm, base thickness is 10mm. This enclosure was originally designed for 30W x 2 class A amp.
12" x 6" x 2" but are vertical so therefore more efficient?
Dan
Old 23rd April 2012, 07:25 PM   #12
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Will This Enclosure Work For F5/F6? Send a message via Yahoo to vdi_nenna
This is directly from the F5 article.
Heat Sinking
At 1.3 amps per channel, you will see idle heat dissipation of 62 watts. To keep the temperature rise of the heat sink to 20 deg C. above the ambient temperature, you will want a heat sink rated at about .6 deg C./watt for each transistor. An example of this would be a chunk of finned aluminum, with a series of 2” fins attached to an 8” by 6” base. You will need two per channel.
If you were to stack the above described heat sink, you'd have a 8"x12"x2" heat sink, or 16"x6"x2" side by side.
I build, therefore I am.
Old 23rd April 2012, 08:03 PM   #13
AudioSan is offline AudioSan  Norway
this depends on your ambient temp. you can have a sink temp of 55C.
so 55-ambient temp=max temp rise.
temp rise/power dissipation= sinks C/W rating.
i have ambient temp of 22C. so 33C max temp rise.
33/64=0.5C/W pr channel.
Old 25th April 2012, 10:45 PM   #14
JZatopa is offline JZatopa  United States
That antek worked great for my F5. I was even able to crank up the bias to about .65v (if I remember right). I did use the black one though.
Old 26th April 2012, 05:19 AM   #15
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
I used the black antek heat sinks from that case and have not had problems with bias up to 0.6. I can keep my hands on them indefinitely. I do have good ventilation though with the bottom being semi open.
Old 27th April 2012, 04:02 AM   #16
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Trademark infringing posts removed
Will This Enclosure Work For F5/F6?Hide this!Advertise here!
First Watt F4 ,F5, F6, F7, F8 ? MikeW Pass Labs 10 6th June 2015 07:56 PM
Would this enclosure work for an F5? JZatopa Pass Labs 5 21st November 2010 04:55 PM
How do you work the enclosure? Allan Tremblay Class D 1 2nd February 2010 01:28 AM
Modushop.biz heatsinked enclosure + F5 Amplifier (Nearly Complete) incl traffo rhysh Swap Meet 10 3rd July 2009 09:08 PM
Whats the strangest enclosure you found to work? Scioneer Full Range 0 20th September 2006 03:54 AM
Copyright ©1999-2017 diyAudio
