#1 | |
Ok,
I decided to get my feet wet and try out the BOZ preamp. For the record, THANK YOU Mr. Pass for sharing your designs with us! Today, prior to beginning my PCB layout, I decided to calculate the gain of the BOZ... Quote:
What this means is that a full scale output of a CD player (let's say 1.5V) would put 12.7V into my Parasound amp. NOT GOOD!! I came to three solutions for my problem. If I make R108 1kohms, rather than 100ohms, I'd have an approximate gain of 0.92 V/V. That suits the purpose much better, I feel. However... this would greatly reduce the current biasing of the FET to 4mA, rather than 40mA. And a large part of the reason the BOZ sounds so good (from what I understand) is that the bias current is able to be set so high. So... that basically defeats the major benefits of the circuit. To get around this (and bring the bias up to 40mA again), the bias voltage could be increased at the gate, but that would require about 44V at the gate... and the Vgs breakdown is about 20V on the MOSFETs. So, that clearly wouldn't work at all. My second solution would be to add a large series resistance to the output in order to create a voltage divider with the input impedance of the Parasound (33kohms). To get the roughly 8.5V/V gain ratio of the default schematic down to about 1V/V, I would have to add about 275kohm in series with the trimmer output of the volume pot. My third solution would be to reduce R104, currently 1kohm. If I made this 100ohms, that would also reduce the gain greatly, close to the desired level of about 1V/V. Unfortunately 40mA through the 100ohm drain resistor is only going to reduce the bias voltage of 60V to about 56V. That means there will be 56V riding at the output. Fortunately, the DC blocking caps I purchased are 100V rated so this would still work i suppose. And the IRF610 is rated for a Vds of 200V, so the FET should be OK too. I just don't know if having 56V at the output is such a good idea... Am I missing something else that would be changed as a result of making this modification???? I surmise that the second solution would sound better than the first, due to the 40mA bias. Granted I will be hearing more "resistor" ... but I think the cons of the restance are greatly outweighed by the pros of the greatly increased biasing. All that, just to ask... "What do you think????" Opinions please!? Many thanks! To avoid any confusion. Right now, I just want to get the BOZ working with my Parasound amp. Buildig a matching Zen amp right now isn't an option I'm considering. Eventually I WILL build an amp... but not at this time. I'm leaning more towards the Aleph designs anyway...
Tieftoener -- You're ears can sense a movement in air that causes your eardrum to move less than 1/10th of the diameter of a Hydrogen atom! Don't abuse the one of the most amazing organs your Creator gave you! |
#2 |
Why don't you use your 20KOhm pots at the input of the BOZ, instead of R107, as a voltage divider. These you can fiddle with till you get the gain you want. Then buy two new pots, preferably with no more than 5KOhm, to be placed at the output. If you ever get to building an amp that requires the full gain, just remove the pots at the input.
Do you really need a pre amp with your Parasound? Perhaps you could go passive. /Niclas |
#3 | ||
Thanks for the reply...
The pot at the input is a fine idea... I just thought it would have lower noise if I kept a full signal from the CD player (or other source) into the FET. It's certainly worth considering I guess... Quote:
I just wanted to get something working - simple, one imput for now. Then I wanted to build another version with multiple inputs to be used with my future Aleph project Any more suggestions!!?!?!?!?!?!?!? Thanks!
#4 | ||
Sincerely yours, Niclas |
| Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? | bembel | Tubes / Valves | 12 | 11th March 2010 05:56 AM |
| need list of "standard" values such as impedance | keantoken | Everything Else | 3 | 30th August 2006 04:40 AM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| A "Standard Noise Source" for SPL meters. | Jonathan Bright | Everything Else | 6 | 13th July 2004 10:19 PM |
| "Standard" EIC power input vs. Filtered EIC | Eric | Everything Else | 16 | 18th May 2001 09:31 AM |
| Page generated in 0.10143 seconds (77.07% PHP - 22.93% MySQL) with 10 queries |
