how change the balance input to unbalance input in PASS amp? how change the balance input to unbalance input in PASS amp? - diyAudio
Old 8th April 2012, 04:12 PM   #1
lilinyi is offline lilinyi
Default how change the balance input to unbalance input in PASS amp?
because my preamp is unbalance output.
question maybe this:
how to connect the RCA input to the balance input?
for example in Alpeh-X(balance input)?
Old 8th April 2012, 04:18 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
RCA hot to pin 2 of XLR
RCA gnd to both pins 1&3 of XLR
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th April 2012, 07:18 PM   #3
WithTarragon is offline WithTarragon  United States
Please keep in mind that when you do what was suggested, you will lose half thge voltage (lose 6dB).
Old 8th April 2012, 07:29 PM   #4
Zen Mod's Avatar
correct , but there is better definition - he'll need double input voltage for same output
Old 10th April 2012, 06:41 AM   #5
nar is offline nar
nar's Avatar
How about the passive balanced input option Nelson often talks about ?
Let's say, define the output Z of your pre. Easy, Use a sine in and a pot on the output.
Adjust pot until read voltage reaches 1/2 of the non loaded output. That is your output Z.
Then, use balanced input of the power amp; but terminate - in by a resistor of same value of Z out on the positive half ...
Any clues ???? That's named "passive balanced" I guess ...
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 10th April 2012, 09:54 AM   #6
I think "passive balanced" is the same as Jensen's pseudo balanced.
The output of the unbalanced source is converted to a balanced impedance output, but with signal only on the hot. The cold is connected to Signal Ground. Pin1 is connected to chassis.
The impedance looking back into the source is identical on both hot and cold. That is a requirement for a balanced connection.
Implement Jensen's modification and your unbalanced source becomes compatible with all balanced receivers.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th April 2012, 09:54 AM   #7
nar is offline nar
nar's Avatar
Thanks AndrewT Acting this way, we'll only get half the gain that would occur by normally shorting - input to ground right (not recommended though as this throws out some gain) ? Whilst retaining noise performance of a true balanced input
Best,
nAr
Old 19th April 2012, 03:51 AM   #8
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
No, No, and No.
If you take an Aleph 2 and short pins 1 and 3, the gain of the amplifier
remains the same.
Passive Balanced? Who knows what they're talking about.
If you want the noise rejection of balanced with a single-ended source,
you do like I showed in the A75 article (how many years ago?).
Use balanced cable and terminate pin 3 through the appropriate value to
ground at the source.
Old 19th April 2012, 09:34 AM   #9
Originally Posted by Nelson Pass View Post
,,,,,,,Use balanced cable and terminate pin 3 through the appropriate value to
That sounds like a description of Jensen's Pseudo Balanced output schematic.
regards Andrew T.
Old 19th April 2012, 10:02 AM   #10
CFMartinD18V is offline CFMartinD18V  Finland
Jensen's term pseudo balanced is referring to a unbalanced-balanced connection where symmetrical cable is used and pin 3 and shield are connected at the source, inside RCA-connector for example. Impedance balanced On the otherhand is a method discribed by Mr. Pass where you connect pin3 to GND at the source with a resistor equal to output impedance.
how change the balance input to unbalance input in PASS amp?Hide this!Advertise here!
TAS5630 damaged when touch the balance input op amp henjoyan Class D 5 16th August 2010 11:29 AM
Why balance input for phono amp? Sunsun22 Analogue Source 37 1st December 2009 09:54 AM
very low noise balance to unbalance converter YUTK Solid State 10 12th November 2005 05:00 PM
Balance Input For Aleph-X thomasfw Pass Labs 2 26th January 2005 04:35 PM
How to convert Unbalance -> Balance Input ? Minh Solid State 21 19th September 2002 11:09 AM
Copyright ©1999-2017 diyAudio
