#11 |
I was one of the mosfet that had died
#12 |
Do you have an idea why?
#13 |
No clue. When I turned the amp off, I head a pop in one speaker. The next time I tried to turn on the amp, it smoked (very hot resistors).
I ran the mosfets at 750 ma each at 32 v rails (350mv drop over 0.5 ohm source resistors). I have chosen to run with lower bias (600 ma) after measuring how much or rather little power I actually use even when I play loud. |
#14 |
This thread started with you suspecting the input JFets. Have you now discovered that one of the power MOS-FETs has failed ?
The MOS-FETs can fail for a number of reasons. However, the most likely is a short in the speaker leads, OR, overheating, OR, a foreign object shoprting MOS-FET to heatsink. |
#15 |
I thought it was the input fets, due to the fact that it was the feedback resistors that got hot/smoked (that was after I had turned the bias down to 0).
After some measurements I found that one of the mosfets was conduction at full power all the time no mater what. |
#16 |
The one and only
It happens occasionally.
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| 1M-F5 - A 1 MHz F5 project | triode_al | Pass Labs | 43 | 25th October 2012 08:28 AM |
| F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 | NYCOne | Pass Labs | 123 | 29th September 2011 12:04 AM |
| F5 Cascoded - an alternative for my interest in the Balanced F5 | NYCOne | Pass Labs | 159 | 24th March 2011 05:23 AM |
| MiniWatt N3 problems, oscillation thumping and RF/motor problems. | Destroyer OS. | Tubes / Valves | 18 | 6th July 2010 12:14 AM |
