Pearl Phono 1 - diagnostic help please
Old 2nd May 2012, 12:29 PM   #11
tnargs is offline tnargs  Australia
Hi, just to update those who generously contributed to my thread:
I replaced the Q4 ZRX450 (again), and still the same voltage measurements, including the base of Q4 being at 1-2 V instead of 13-14 V.
So now I have ordered replacement Q6 and will replace Q4 and Q6 simultaneously. I will let you know how it goes.
cheers
Old 4th May 2012, 05:54 AM   #12
h_a is offline h_a  Europe
h_a's Avatar
Typically the jfet blows and takes the ZTX with it; this is the very most common failure for the pearl. In that case replace both as otherwise the remaining damaged jfet will again take down the ZTX.
where DO you get a genuine 2SK389?
The K389 is not needed in this position, you can as good use the K170BL or even selected K369GR. These also have twice the power dissipation of the single jfets in the K389, so reliability will no longer be a problem with these replacements.
Hannes
High Octane phono preamp Wiki
Old 6th May 2012, 02:06 AM   #13
Originally Posted by h_a View Post
Typically the jfet blows and takes the ZTX with it; this is the very most common failure for the pearl. ....
Ha! NOW I discover this! I have been alternately blowing each one when I replace the other....
Anyway, I have bought 25 K170BL and will replace Q4 (ZTX450) and Q6 (with a matched pair of 170's) together and report back.
Thanks again all.
Old 7th May 2012, 05:50 AM   #14
h_a's Avatar
Just for your information - there is absolutely no matching necessary in this position. Of course you can do it if you simply feel like it.
However, use the highest IDSS BL-jfets that you have in this position and you'll get a bit lower distortion.
Hannes
Old 7th May 2012, 10:04 PM   #15
Thanks Hannes, will do.
Old 15th May 2012, 03:09 AM   #16
Fixed! Replacing both components together did the trick. Measured DC voltages are now as expected.
A quick listen gave the impression of less output on the repaired channel, but this needs to be confirmed.
Thanks again to those who helped!
Old 15th May 2012, 06:04 AM   #17
h_a's Avatar
Fixed!
Great!
Might happen if your jfets are on the other end of the IDSS scale compared to the ones in the other channel, but still the difference should be very small.
Hannes
Pearl Phono 1 - diagnostic help pleaseHide this!Advertise here!
Help - Balanced Pearl Phono Irakli Pass Labs 16 1st August 2016 03:58 PM
Pearl Phono Preamp bfard Pass Labs 2 26th March 2007 03:25 AM
pearl phono bernification Pass Labs 2 7th February 2006 08:44 PM
Pearl Phono Done (almost) Gregorio Pass Labs 0 16th January 2006 01:42 PM
pearl phono hsort Pass Labs 5 2nd March 2002 09:26 PM
