Zen 9 - Troubleshoot Bad Channel
Old 7th April 2012, 08:24 PM   #1
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Zen 9 - Troubleshoot Bad Channel Send a message via Yahoo to vdi_nenna
Default Zen 9 - Troubleshoot Bad Channel
Hi, have problem with one channel on Zen 9. Other channel works; plays music.
No burned parts in bad channel
Tried replacing jfet and mosfets, but did not fix issue.
Did not replace ZTX450 in CCS yet.
Good channel warms up, but bad channel does not warm up at all.
Grounding is a star ground to chassis ground via thermistor, then to earth ground. Each channel has its own star ground.
Both channel go to ground through its own thermistor. Running 1 ground connection from board to star ground. Did not use grd for input. Chassis input grd goes to star ground. Board is single-sided.
When applying power, bad channel ramps up in voltage, but eventually voltage drops back to zero. Only happened on first start up and when replacing all fets. After, first startup, the voltage appears as shown below.
Q2 is 0v.
Voltage at power supply (dual mono) before connecting to the amp circuit- 51.8v
Voltage at power supply with bad channel 51.8v
Voltage at power supply with good channel 45.1v
Good channel voltages:
Q1:
G- .2v
D- 5.5v
S- 1.5v
Q2:
G- 9.3v
D- 23v
S- 5.4v
Q3:
G- 44.4v
D- 45.0v
S- 41.0v
Q4:
G- 27.4v
D- 41.1v
S- 23.9v
Bad Channel Voltages:
Q1:
G- 0v
D- 0v
S- 0v
Q2:
G- 0v
D- 0v
S- 0v
Q3:
G- 0v
D- 49.4v
S- 0v
Q4:
G- 51.2v
D- 51.8v
S- 49.2v
Wanted to get some advice before removing bad channel from amp.
Like to know if there are other test I can run.
Thanks in advance!
Vince
I build, therefore I am.
Old 8th April 2012, 12:29 AM   #2
vdi_nenna's Avatar
Got it working. Must have been Q5 and a resistor next to it.
Reflowed the solder join for the resistors. Listening now on test speakers. :-)
Old 8th April 2012, 12:33 AM   #3
Dennis Hui is offline Dennis Hui  Canada
Glad you found the problem. Happy listening.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 8th April 2012, 12:39 AM   #4
vdi_nenna's Avatar
Thank! Very happy right now!
Sounding good even through a mini set of speakers.
Old 19th April 2012, 07:18 PM   #5
vdi_nenna's Avatar
Does anyone know why the power supply sags to 46v at the power supply output, instead of 50v? With no amp circuit, after the PS caps, it's closer to 51v, but when the circuit is attached, it drops to 46v.
Had to adjust P1 for around 20-21v at drain of Q2. Also, the pot is down to its lowest setting. It will not drop the voltage lower. As you can see in the photos, each channel has its own transfromer and caps.
Any ideas? I'm sure the two issues are somehow related.
Thanks,
Vince
Old 20th April 2012, 06:02 AM   #6
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
What are the transformers VA rating?
Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 20th April 2012, 10:55 AM   #7
vdi_nenna's Avatar
Antek AS3218, 300va, 8.3A, 18+18v
Old 20th April 2012, 11:26 AM   #8
Vince,
Looking at the datasheet for your transformer ( http://www.antekinc.com/pdf/AS-3218.pdf ), the voltage seems a bit low to me, especially under load.
Are you using CRC in your power supply? If so, perhaps you can measure
the drop across R to see if it might be a significant amount.
Dennis
- NP 2002
Old 20th April 2012, 11:54 AM   #9
AudioSan is offline AudioSan  Norway
what??? around 2V at full power. is that a high voltage drop?
or was it the 5V drop you ment was a ittle high?
Old 20th April 2012, 12:57 PM   #10
vdi_nenna's Avatar
Dennis, you might be on to something there. I used a single 1 ohm resistor between 30k uF caps. I'll check the voltage drop tonight. I followed a CRC power supply designed for another amp. Probably should have stuck with the three .47 ohm in parallel, that's only .156 ohms.
Could get approximately the same value by adding a .33 and .47 ohm resistors in parallel with the 1 ohm for .162 ohms. Sound possible?
The transformers are each rated almost 4x the current draw of 2.2A.
Not saying it's impossible, but unlikely that they can't supply the voltage.
Thanks,
Vince
Zen 9 - Troubleshoot Bad ChannelHide this!Advertise here!
Please help me troubleshoot Niles Audio SI-1230 12 channel amp johnbomb Solid State 4 3rd April 2012 08:03 AM
xtant 4180c bad channel rjam5 Car Audio 1 11th February 2012 07:01 AM
CD Player with one bad channel ggilliland Digital Source 3 25th January 2012 10:51 PM
Bad channel on a Eclipse XA4000 wrxer Class D 0 25th December 2011 01:19 AM
rockford 501s one bad channel stoke Car Audio 18 23rd February 2011 04:43 PM
Copyright ©1999-2017 diyAudio
