| View Poll Results: F5T 19n20C replacement | |||
| FQA19n20L |
0 | 0% |
| FQA12n25C |
10 | 83.33% |
| FQA32N20C |
0 | 0% |
| FQA28N15 |
0 | 0% |
| FQP TO220 |
2 | 16.67% |
| Multiple Choice Poll. Voters: 12. You may not vote on this poll | |||
#101 |
Samples sould arrive today or tommorrow. I will have transfer curve comparison between 19n20C and 16n25C. If these are close, I wouldnt expect any real signifiant deviation anywhere else considering how close the two datasheets match.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#102 |
buzzforb, I've done quite a bit of MOSFET testing in the past few years. I can at lest help you out witht the theory. I've probably done all the other tests though. Most were RdsON, Idsmax, SOA curve data, performance in switching applications, etc. Swithching stuff is not what we want but I understand all this raz ma taz pretty well...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss Last edited by flg; 24th April 2012 at 03:40 AM. |
#103 |
Thanks FLG. I appreciate the offer. I have the fets, but waiting on some test bed components. I should have some numbers in next couple of days.
#104 |
Here is the basic comparison.
Measured across .1R 1% source resistor
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! Last edited by buzzforb; 9th May 2012 at 01:10 AM. |
#105 | |
Can you adjust something to get them to overlay, or are you pointing out that they are too different? Rush |
#106 |
This would suggest that they are very similar.
#107 |
Little update. Almosr done with N channel. Matching is good. P Channel not as good, but OK. I have acces to more and may have to get them to ensure matches, but all looks good. I wouls day that shipment within 4-6 weeks is likely. Thanks.
#108 |
Buzzforb, are you using locky_z's curve tracer to do the matching? Thanks.
#109 |
Began with traditional methods. Didnt start using curve tracer until after i verifed its performance against fets matched using traditional methods. Results are very repeatable using both methods. For curve tracer matching, i test them, sort them by Vgs and then retest again before final sort.
| Fairchild interest. | buzzforb | Pass Labs | 257 | 15th November 2012 11:59 PM |
| Fairchild transistors | GregH2 | Parts | 1 | 28th August 2011 02:53 AM |
| Fairchild A00-6 | rusocubano | Solid State | 0 | 22nd August 2011 01:08 AM |
| Fairchild FJA4310 | jgray | Solid State | 7 | 11th November 2010 05:29 PM |
| Fairchild IRF540A | richie00boy | Parts | 8 | 22nd June 2004 11:39 AM |
