Fairchild interest alternatives
View Poll Results: F5T 19n20C replacement
FQA19n20L 0 0%
FQA12n25C 10 83.33%
FQA32N20C 0 0%
FQA28N15 0 0%
FQP TO220 2 16.67%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Old 9th April 2012, 03:36 PM   #11
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am almost 100% sure that i have secured what i believe to be the best alternative to the 19n20C. I have one more lead on the original, but if it doesn't pan out, I would suggest FQA16n25C. I will provide links to both datasheets and I believe you will see that they are almost identical in performance.
FQA19n20c link from digikey
MOSFET N-CH 200V 21.8A TO-3P - FQA19N20C
FQA16n25c
MOSFET N-CH 250V 17.8A TO-3P - FQA16N25C
This should allow you to get datasheet direct from Digikey
...Shape the sound , Man!
Old 9th April 2012, 03:38 PM   #12
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
The system cannot find the path specified
" If you're going throu hell, keep going"
Old 9th April 2012, 04:31 PM   #13
flg is offline flg  United States
flg's Avatar
Well, a fine spot we are in eyy? About now, I believe it is time to look back on some comments Charles Hansen made...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 9th April 2012, 04:58 PM   #14
buzzforb's Avatar
I remember reading this conversation. Fortunately, the P channel parts are not in question and the N channel substitute seem to match the original spec'd part extremely well. Better so than the standard 19n20 part that would be next in line in the 19n family.
Old 9th April 2012, 05:25 PM   #15
buzzforb's Avatar
Here is a link with Nelson commenting on the original parts.
Fqa12p20 Fqa19n20c Discontinuation
Old 10th April 2012, 01:18 PM   #16
buzzforb's Avatar
I can get FaArichild orginal FQA16n25C parts in sealed boxes. I have some samples on the way and will provide a comparison between it and the orginal 19n20c part. If all looks good, then i will put it into an F5T and try to get some distortion numbers to compare to the article. I also will try to contact all GB members and inform them of what is happening.
Old 11th April 2012, 08:38 PM   #17
diy newbie
oiphy's Avatar
so I checked out the datasheets and I agree with you buzzforb, seems that the 25c series is a good place to start. I applaud you for youre tremendus effort with this gb.
Stig
Old 11th April 2012, 08:50 PM   #18
pddjsteve is offline pddjsteve  United States
Thanks for all the work you've put into this. I'm behind whatever the group at large decides, so far it sounds like the 16N25C is the way to go.
Old 11th April 2012, 09:15 PM   #19
dr.strangelove3 is offline dr.strangelove3  Netherlands
dr.strangelove3's Avatar
Hi buzzforb,
Also thanks for all the hard work and the substantial investment on your part!
I'll go with the part you decide.
Old 11th April 2012, 09:29 PM   #20
flg's Avatar
Thanks buzzforb. I agree, the 16N25C is an excellent replacement for the 19N20C. I haven't had time to do the research on Charles Hansen's suggestion of basically selecting a higher voltage complement to get the Transcunductance down to match the P part. I use a 150V part sometimes that is 20S! I think we should look for 400V N parts?
Fairchild interest alternativesHide this!Advertise here!
Fairchild interest. buzzforb Pass Labs 257 15th November 2012 11:59 PM
Fairchild transistors GregH2 Parts 1 28th August 2011 02:53 AM
Fairchild A00-6 rusocubano Solid State 0 22nd August 2011 01:08 AM
Fairchild FJA4310 jgray Solid State 7 11th November 2010 05:29 PM
Fairchild IRF540A richie00boy Parts 8 22nd June 2004 11:39 AM
Copyright ©1999-2017 diyAudio
