My F5 Lives!!!!!!! - Page 2 - diyAudio
Old 6th April 2012, 10:45 AM   #11
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by AudioSan View Post
thats a standar F5 with 30% higher bias. but stil +/-24V rails.
EDIT: F5v2. CViller boards. (not turbo v2)
36 watts rms@8 , sounds like you are using 4 ohm speakers , small room and listen moderately (82db avg din) ...
Old 6th April 2012, 12:36 PM   #12
8ohm. not to big room.
Old 6th April 2012, 12:49 PM   #13
fab is offline fab  Canada
fab's Avatar
Originally Posted by dantwomey View Post
...Now to my first impressions. In my system the F5 has a warm and liquid midrange that gives this amp a very lifelike smoothness. But this smoothness comes at a price. The high end is softened and less detailed and lacks the sparkle of my gainclone. If I could restore this sparkle and detail without any accompanying glare this would take the F5 up a notch for me. ...
Hi
I have built a Gainclone LM3886.
I have built a standard F5 (no input cascode).
If you want the soundstage, smoothness and sparkles, try:
F5 meets Buzquito
You can run this amp with about up +/- 30 Vdc to get a little more voltage swing.
The bass is not as tight as the Gainclone though but you are right about the missing soundstage of GC compared to F5.
Fab
Old 6th April 2012, 02:19 PM   #14
Originally Posted by 6L6 View Post
Check your bias. It might not be stable once things get all warm and toasty.
Once assembled my amp has no room to check anything. I setup bias using a spare heatsink and the PS from this amp. The heatsinks get nice and toasty with myself only being able to leave my hand on for the required ten seconds!
Dan
Old 6th April 2012, 02:21 PM   #15
thats a lack of gain. when you run out of power, your amp has started clipping.
It's probably my preamp. At full power things are very smooth with no clipping or 'bad sounds'.
Dan
Old 6th April 2012, 02:23 PM   #16
then it is lack of gain.
Old 6th April 2012, 02:27 PM   #17
Actually my speakers are 10 ohm in a very large (18' x 27') room.
Old 6th April 2012, 03:44 PM   #18
expert in tautology
bear's Avatar
ur room is a bit live...
the F5 has no strain in the sound of highs...so you may be playing it much louder than you think...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 6th April 2012, 04:01 PM   #19
oneplustwo's Avatar
I don't see a F5 in those pictures...
Old 6th April 2012, 04:25 PM   #20
Dan
If I understand you correctly, that's a problem. Bias will vary with whether or not the top is on, and you cant check it on the assembled amp? Time to start over. You need to be able to get to and measure bias with the amp assembled, and be able to get to the adjustment pots. This is probably why your amp has no "sparkle"......Should be clear and transparent with plenty of sparkle, some complain of too much...Hopefully I misunderstood?
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Tetra lives!!!!! MrBurd Tubes / Valves 6 2nd October 2012 12:32 AM
She lives! flyinglemur Tubes / Valves 2 19th July 2008 11:49 PM
It lives! pjanda1 Chip Amps 1 21st May 2005 12:24 AM
How the other half lives harvey Everything Else 9 27th February 2003 12:55 AM
The Mini-A lives! Thomas Pass Labs 27 23rd November 2002 09:51 PM
Copyright 1999-2017 diyAudio
