My F5 Lives!!!!!!!
My F5 Lives!!!!!!!
Old 6th April 2012, 04:38 PM   #21
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
Just as one data point, my bias would go up about 20-30mV with the cover off vs. with the cover on.
Old 6th April 2012, 04:43 PM   #22
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
My F5 Lives!!!!!!! Send a message via AIM to Peter Daniel
Originally Posted by dantwomey View Post
The high end is softened and less detailed and lacks the sparkle of my gainclone. If I could restore this sparkle and detail without any accompanying glare this would take the F5 up a notch for me.
If it's a stock F5, you may improve it by removing current limiting circuitry.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th April 2012, 04:55 PM   #23
fab is offline fab  Canada
fab's Avatar
This shows also an increase of gain
Old 6th April 2012, 06:38 PM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Actually my speakers are 10 ohm in a very large (18' x 27') room.
The 10 ohm maybe your problem , you have 22 watts to drive your speakers ...
Old 6th April 2012, 07:27 PM   #25
dantwomey is offline dantwomey  Canada
Two updates. After a brief investigation the lack of power seems to be my preamp. More on that soon.
As for the lack of sparkle. For the last couple of years I had a series of 'bright' amps so I toned down the HP crossover on my line arrays. I may look at reversing those changes to see if it helps my F5.
None of my line array pics have my F5 in it. New pics of my F5 soon.
Dan
Old 6th April 2012, 07:34 PM   #26
This is the circuit I built. I didn't realize I could eliminate R7 and R8. I didn't measure voltage drop across R3 and R4. I just made sure the Vdrop across R11 and R12 was 600mV and DC offset on the output was near zero.
Dan
Old 6th April 2012, 07:45 PM   #27
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
My F5 Lives!!!!!!!
IME sparkle, shimmer, sizzle, etc are undesirable and suggest distortion or noise. The cleaner my top end has become, the 'darker' and 'richer' overall the sound has become, while the treble is smoother and more delicate and revealing than ever, and the sound also has better micro dynamics, making it sound louder and more explosive at the same volume setting as previously -- like live sounds.
(A couple of weeks ago, I went from CRC to CLC on my class AB amp and cannot believe the improvement everywhere....!)
Old 6th April 2012, 08:04 PM   #28
Andersonix's Avatar
My F5 Lives!!!!!!!
The F5 circuit you built doesn't have the current limiting that the 'original' F5 has.
Old 6th April 2012, 08:30 PM   #29
Sin Bin
Which amp ....? Differences noted ? CLC values would be appreciated ....
Old 6th April 2012, 08:56 PM   #30
Andersonix's Avatar
My F5 Lives!!!!!!!
CRC to CLC update here
My F5 Lives!!!!!!!Hide this!Advertise here!
Tetra lives!!!!! MrBurd Tubes / Valves 6 2nd October 2012 12:32 AM
She lives! flyinglemur Tubes / Valves 2 19th July 2008 11:49 PM
It lives! pjanda1 Chip Amps 1 21st May 2005 12:24 AM
How the other half lives harvey Everything Else 9 27th February 2003 12:55 AM
The Mini-A lives! Thomas Pass Labs 27 23rd November 2002 09:51 PM
Copyright ©1999-2017 diyAudio
