Aleph 5 DC feedback capacitor (C5) reverse polarized
The capacitor C5 is used in the Aleph 5 to provide 100% feedback at DC. The capacitor can have forward or reverse voltage applied, however in the drawings this is a polarized capacitor. I'm not too worried about this, because most electrolytic caps can withstand 1-1.5V applied in reverse polarity. But when attaching or detaching cables, a high-voltage spike may be encountered (hence the zener protection for the MOSFET gate), and I'm wondering if this has any potential to damage the capacitor.
Is it possible for an AC signal to damage an electrolytic capacitor, or is that a problem only with extended DC reverse charge? Should I use a solid electrolyte capacitor with higher reverse tolerance?
The failure mode is not spectacular: it will simply lead to less feedback at DC. However this might change the DC output offset of the amp and damage the speaker.
I believe electrolytic capacitor failure due to reverse-biasing is related to power dissipated; within reason, reverse voltage without significant current won't damage them. An AC signal with sufficient current can most certainly blow these caps, but one that supplies only a few mA, probably will cause no problem or a slow degrading of value.
