Old 30th September 2003, 11:49 PM   #1
Default Dual outputs for Balanced Line Stage Preamp
What would be the consequences on performance of the Balanced Line Stage Preamp if one were to run two sets of outputs in parallel? Say, one to a main power amp like the ZenV4, and a second to a powered subwoofer. The article says that the preamp can drive low impedance loads (like 600 ohm) with no decrement in performance, except gain. Can one infer that (given most components input impedance) one could therefore drive two devices in parallel, as described above? I have two outputs on my old Jung modified Dyna Pat-5, and it seems to work driving the amp/powered subwoofer configuration. I would like to scrap the Pat 5 and do the same trick with the BLS, when it is done.
Also, what if the main amp were run balanced (e.g., the Pass A-75). Could one simultaneously drive the subamp in unbalanced mode somehow?
Larry Wright
Seattle area
Old 1st October 2003, 12:44 AM   #2
lgreen is offline lgreen  United States
lgreen's Avatar
Default dont see why not
I don't see any problem with driving two balanced outs. The impedance will be lower but the circuit should handle it. I'm putting two balanced AND two unbalanced outputs on mine, but since its not yet done, I have nothing to report. While I don't intend to run them all simultaneously I suppose I could.
Also, I don't see anything wrong with driving balanced out and an unbalanced out, note that the balanced will be twice the amplitude as the unbalanced so your downstream stuff will have to compensate. Also depending on how you wire your unbalanced (taking the plus or minus output at the center pin and ground at the outer contact), it may be 180 degrees out of phase with your balanced, so check this to ensure its in-phase.
Old 1st October 2003, 09:33 PM   #3
Thank you, lgreen; your response is spot on for the questions I posed. I will plan for dual outputs and connect accordingly. Especially interesting was your point that an unbalanced output in parallel with a balanced one would have half the output of the latter. This makes some intuitive sense to my unschooled brain, but I never would have been able to reason out this fact for myself. Merci Beaucoup.
Larry Wright
Seattle area
Old 2nd October 2003, 01:02 AM   #4
Banned
balanced and SE load in parallel - wouldn´t this cause an asymteric load on the positive and negative outputs? and so degenerate the balanced signal that way amplitude of these is different value?
Old 2nd October 2003, 01:32 PM   #5
nobody special's Avatar
I was thinking the same thing. Maybe it would be best to add a load resistor on the unused line in an attempt to keep the impedance balanced on both phases?
Nobody
Old 2nd October 2003, 05:34 PM   #6
jam is offline jam  United States
jam's Avatar
How about buffering one set of outputs- to the subwoofer, minimal sonic damage.
Jam
Old 2nd October 2003, 06:36 PM   #7
Jam
Good idea.
If you're going that far, why not put the crossover in the preamp too.
Nobody
Balanced (preamp) Outputs - Why ? ronzeman Solid State 9 24th January 2009 09:44 AM
Building a Preamp:Dual Outputs Question mourip Tubes / Valves 3 21st May 2006 07:19 PM
Preamp with balanced outputs miguel2 Chip Amps 9 5th May 2004 02:19 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Balanced Line Stage vs. ad811 based preamp audionut Pass Labs 6 3rd March 2002 11:23 PM
Page generated in 0.09233 seconds (77.21% PHP - 22.79% MySQL) with 10 queries
