F5X Case
F5X Case
Old 28th March 2012, 05:15 PM   #21
EUVL is offline EUVL  Europe
Greg,
Thanks for the great effort for putting this together.
It is still early days, as you have not really seen the completely finished amp as yet.
But if the response is good, and there is sufficient demand, we shall open a second batch in summer 2012.
As already mentioned elsewhere, this time we shall supply everything other than things you can order from Digikey or Mouser without matching.
So you don't have to join 10 Group Buys and make 10 payments, and go to the Customs 10 times.
Please give Greg & Co a change to finish the amp completely, and we'll take it from there.
Thank you for appreciating our work,
Patrick
xen-audio.com
Old 28th March 2012, 05:23 PM   #22
qusp is offline qusp  Australia
qusp's Avatar
Nice work on the guide so far Greg!
Old 31st March 2012, 01:42 AM   #23
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by Horio View Post
Unpack the rear panel, rear bracket and rear panel handles.
First mount the auxiliary transformer to the rear panel using the M5 x 35mm countersunk bolt. Next mount the rear panel to the rear bracket with (8) M3 x 10mm button head bolts. Lastly, fasten the handles to the rear panel with (2) M4 x 10mm bolts per handle.
What are the other 2 countersunk holes on the rear panel bracket for?
Old 31st March 2012, 02:07 AM   #24
3, I think.
The middle one is for the Aux Tx. Two on the sides are for the Speaker Protection Relay.
We ourselves are using Automotive Relays 70A 24V with mounting lugs in shunt mode.
American ZETTLER, Inc.: Electromechanical Relays Product Detail
Patrick
xen-audio.com
Old 4th April 2012, 10:17 PM   #25
Horio is offline Horio  United States
Horio's Avatar
Patrick
I was looking at the GB ashaw is running, and he is showing the 12V version of the AZ797 relay. I guess I am a little confused which coil voltage is correct.
Old 5th April 2012, 04:02 AM   #26
That depends on how you connect the relays.
The relay driver will deliver 24V.
You can use two relays 12V in series, or 2x 24V in parallel.
The net current is about the same.
Probably 12V is easier to get, and is safer in series.
(So both relays drop out together for sure.)
In the schematics that we posted, the relays were shown to be connected directly to 24V.
F5X -- the EUVL Approach
Alexis please kindly confirm.
Patrick
xen-audio.com
Old 6th April 2012, 01:14 AM   #27
jpak is offline jpak  United States
jpak's Avatar
Stunning case, very nice work Greg.
Old 6th April 2012, 02:15 PM   #28
Horio's Avatar
I'd love to take credit for the design, but that must go to EUVL and MarkLai. Most definitely a stunning case.
Old 6th April 2012, 02:49 PM   #29
jpak's Avatar
I wouldn't mind if the faceplate was something similar for the T2
Old 6th April 2012, 03:46 PM   #30
wirewiggler is offline wirewiggler  United States
Outstanding work on the case in fact the attention to detail on the entire project is commendable. I have to admit I would have like to jump in on this one but the logistics of all the group buys looked a bit tedious. If you do a second buy with everything grouped together ( I know I am being lazy)and I am caught up on my projects I may participate just because it looks so cool.
Bill
F5X CaseHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
F5X Transformers mravinsky Group Buys 122 16th February 2012 06:18 PM
F5X Transformers mravinsky Group Buys 1 10th January 2012 04:40 PM
F5X using Peter Daniel boards? speakrsrfun Pass Labs 2 16th November 2011 06:15 AM
Copyright ©1999-2017 diyAudio
