Old 27th March 2012, 09:17 PM   #11
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Papa said, on the very first page of the F5Turbo article: "RTFM". That goes for both the original F5 and the F5T variants. Voltage options are explained in detail.
You HAVE to invest yourself into this whole DIY concept else the questions will go on exponentially. I really do not mean to offend, but 10 posts later, you are confused and pretty much giving up?
Old 28th March 2012, 12:26 AM   #12
You're overlooking a basic rule-of-thumb for power supply design, and perhaps your buddy is, too......
For a properly designed DC power supply, the output (rail) voltage is 1.414 times the input voltage (i.e., the voltage supplied by the transformer secondary winding).
In your case, with a 25 VAC secondary:
25 x 1.414 = 35.35 VDC, per rail.
This is pushing the limit for a "plain vanilla" F5 amp.....which is what the chain of comments (above postings) are telling you.
A hint: If you are missing this simple power supply design point, building the F5 itself may be a challenge for you. You should really study the design topology (and understand it), and know what your bias settings do to the amp in practice. Read the First Watt articles, and browse the (long) F5 thread and F5 Turbo materials. It will help you quite a bit.
If you go with a simple F5, I'd recommend you scrap your current transformer. I'd also recommend you send it to me for proper disposal--but only, of course, if it has dual primaries I can be configured for 120 VAC mains....
Old 28th March 2012, 03:57 AM   #13
Default Cool.
Originally Posted by bassnkeys View Post
I found one this... seems about right to me. Is that enough current?
Thanks,
DB
Electrical Characteristics
Outputs2x Power300VA Output Voltage Current 18V8.3A
I guess 18 x 1.4 puts me right in the voltage zone.
Thanks,
DB
P.S.
My F5 boards are heat sinked and up and running from my friend's bench power supply. He worked with me through the initial start up as per Pass's instructions.
WTB: used transformer for F5 amp DJNUBZ Swap Meet 0 13th April 2011 07:21 PM
F5 Single Primary Transformer NV&H Pass Labs 15 28th June 2009 09:57 PM
F5 Assembled Boards and A Transformer For Sale lgreen Swap Meet 4 18th May 2009 02:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
