Aleph 30 the best choice of C1 C2 C3 on  brian gt PCB
Old 4th August 2012, 10:24 AM   #151
wengtech is offline wengtech
there is hum and hiss when setting like this: (dc out 80-300mV)
but will be silent with this setting: (dc out 0-25mV)
Old 4th August 2012, 10:36 AM   #152
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
1. setting DC offset and bias - all inputs grounded , amp hot , lid on (take it off just for quick re-set)
2. first pic is correct for unbalanced input
3.second pic is example of nada,zilch,hogwash ; neg leg input is floating , and you're not having full gain ; it is not balanced config
so - for proper operation - either connect it as per pic 1 , for unbalanced (RCA ) input , or bring proper balanced signal (as XLR wiring - remember that ? )
give us more pictures , so we can comment your grounding scheme and find culprit why you are having hiss & hum
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th August 2012, 11:21 AM   #153
yes Zen Mod, i know how to wire XRL or RCA'
the pic above only to shown the changes dc output voltage with -IN shorted and unshorted.
this is basically i do with the amp:
Old 4th August 2012, 12:36 PM   #154
Zen Mod's Avatar
you must ground both inputs (+ and - ) when setting offset
have you any pic of your PSU pcb layout ?
I mean , traces - that will help to see is there any room for improvement
Old 4th August 2012, 01:21 PM   #155
okay i see both + and - are grounded.
this is my PSU wiring:
bleeder R and bypass Caps i mean:
according to mr pass files,
there are no setting for this amp.
so, which component should be setting?
Old 4th August 2012, 03:08 PM   #156
i am using un matched IRFP244.
so voltage across each 0.47ohm are:
Right Ch: Left Ch:
R34 = 397mV 434mV
R35 = 517mV 486mV
R36 = 434mV 412mV
R37 = 508mV 496mV
R38 = 481mV 414mV
R39 = 363mV 438mV
original pass file, it should be 250mV across that resistors.
i am using this schematic:
Old 4th August 2012, 07:24 PM   #157
Zen Mod's Avatar
pcb seems adequate
so - for that pcb,best takeout point for gnd routing to output pcbs is point where you connected two wires from bridges , establishing gnd .
regarding Iq - do you hear benefit of increasing it , ref. original ?
Old 6th August 2012, 10:39 AM   #158
this is my first time to build aleph30 amp.
so i dont know what is the difference.
i am planning to re-wiring my PSU like this one:
what do you think? will this solved the hum and hiss problems?
thanks.
Old 6th August 2012, 10:42 AM   #159
Zen Mod's Avatar
it'll be probably just fine
do not forget to put 10R/5A NTC between audio GND and chassis
Old 6th August 2012, 11:12 AM   #160
yes of course,
each channel will be equipped with :
- 2x2k2/2w as bleeder,
- 2x1ohm/5w in parallel on each rail to perform CRC,
- and 2xwima4.7uF/400v as bypass caps.
i hope this is enough for my aleph30.
Aleph 30 the best choice of C1 C2 C3 on  brian gt PCBHide this!Advertise here!
Brian GT Aleph and PS boards mattattnet Swap Meet 2 17th September 2011 03:10 AM
Axials for C1/C2 on SSE? dr0ss Tubelab 5 28th August 2010 09:50 AM
Aleph 5 with Brian GT boards. (help) edoirt Pass Labs 11 31st July 2006 06:15 PM
C1 and C2 in BoSoZ ruangrit Pass Labs 3 29th January 2003 04:06 PM
