Aleph 30 the best choice of C1 C2 C3 on  brian gt PCB
Old 7th April 2012, 04:05 PM   #111
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you got it !
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th April 2012, 08:10 PM   #112
tonimxp is offline tonimxp  Italy
Originally Posted by boywonder View Post
If I had one I would try it......I'm going to do the other channel and listen for a while.
I'll order a few values on my next Digikey order.
Hi!BW some good news after mod?
Old 17th April 2012, 09:27 PM   #113
boywonder is offline boywonder  United States
boywonder's Avatar
Yes, it sounds quite nice. It's in my main rig presently, and I don't think I can mod it any further with the transformers that I've got. I suppose that I could reduce the source R's for more current but my rails are already about 13.8V. I also replaced the generic bridges with FREDs. It has a very tiny bit of sibilance compared to my 300B amp and great imaging; I'll be comparing it to my 300B SET over the next few weeks. It now gets quite warm but I can keep my hand on it indefinitely (barely, though).
Old 18th April 2012, 12:27 PM   #114
Hi!If the comparation is with a 300b amplifier based i think it is a big target!
But have you noted some differences with (C4/R15 net) changed value in terms of sound?
Old 18th April 2012, 02:25 PM   #115
boywonder's Avatar
I'm comparing it to a 300B SET mostly because they are about the same wattage (8W). I'm running 95db sens FR speakers (Half Changs with TB 1772's in them presently). I like the 300B amp better, but the mini is really nice, it was a fun project.
I imagine that the mini has lots more damping factor than my triode tube amps, but I'm also using a subwoofer so in terms of bass I usually have to readjust the sub a little when I switch amps anyway. This could be a combo of DF differences and amp input sensitivity differences.
I'd Like to think that changing C4 has reduced sibilance and helped the imaging but that may just be my imagination.
Old 26th April 2012, 10:07 AM   #116
vivanco is offline vivanco  Italy
I have finished the construction of my ALEPH 30, I think I did a good job, because the sound that the amp produces is excellent, dynamic and reconstruction of the stage at very high;
actually, what I read about this amp on the high power dissipation, corresponds to reality, in fact my aleph very hot after a few minutes;
I still want to ask a question relative to the supply voltage, ie, there are contraindications to the fact that my aleph is fed with 27.5 / 0 / 27.5 VDC?
Uploaded with ImageShack.us
this is my preamplifier ALEPH P1.7, which mate with the amplifier 30 ALEPH
Black version for a friend
Old 26th April 2012, 10:09 AM   #117
Zen Mod's Avatar
nothing to worry about , except heatsink temp
Old 26th April 2012, 10:37 AM   #118
I understand ....i you ask, I can feel comfortable because I listened to my aleph for about 5 hours,,,the dissipation was constant? (I plan to measure the temperature at the next opportunity), that you could hold your hand on them only for about 7-8 seconds.
thanks ZEN
Old 26th April 2012, 02:48 PM   #119
gadut is offline gadut  Indonesia
gadut's Avatar
@vivanco
I think that your heatsink is too small for alpeh30, my friend use the same casing for mini aleph, and it's hot. Just wondering the temp on yours
Old 27th April 2012, 08:12 AM   #120
Originally Posted by gadut View Post
@vivanco
it seems very strange that you say, because I have also created a mini aleph that sounds very very good and, as you can see from this photo,
I used a chassis HIFI2000, namely the heavy model dissipating unit 3, which has cooling fins 11.8 "x 4.72" x 1.57 ", however, the cooling fins are hot (not boiling) in the area where the mosfets are mounted, while the edges are barely lukewarm, so I wonder how it is possible that the mini aleph your friend produces a warmth that is the limit of endurance of the cooling fins mounted on the chassis that I've shown before, whereas are 15 "x 6.3" x 1.26 "??
note, my mini aleph is powered with 18/0/18 VDC
Aleph 30 the best choice of C1 C2 C3 on  brian gt PCBHide this!Advertise here!
Brian GT Aleph and PS boards mattattnet Swap Meet 2 17th September 2011 03:10 AM
Axials for C1/C2 on SSE? dr0ss Tubelab 5 28th August 2010 09:50 AM
Aleph 5 with Brian GT boards. (help) edoirt Pass Labs 11 31st July 2006 06:15 PM
C1 and C2 in BoSoZ ruangrit Pass Labs 3 29th January 2003 04:06 PM
Copyright ©1999-2017 diyAudio
