#31 |
#32 |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#33 | |
Since Talema only have maximum rating on 18V @225VA, is it big enough for 1 channel? or should I get bigger one such as Antek 2x18V 400VA?
#34 |
just use what's easier to buy/pay/ship
it's anyway hard to sim properly if you don't have exact Rdc values of both primary and secondary R in CRC will take care of excessive current suck from rectifier and xformer anyway, be sure that 4x47mF will be already perfect for one channel
#35 |
2 x 18VAC????? ![]() I do not remember where or who, but I'm sure you informed on the need to have 2 x 22VAC to power aleph 30 and, in the case of common power supply for both channels, the filter formed by CRC 4 x 22.000uF / 2 x 1 ohm 10W / 4 x 22.000uF |
#36 |
oh boy ........
well - I'm sure that I made my homework ........ ![]() all roads lead to Rome if you want 25V caps , 2x18Vac will give you roughly 2x22Vdc if you use higher voltage caps , be my guest and use up to 25Vac xformer 1R in CRC is a hell , if you ask me
#37 |
Always look at schematic before doing changes
I don't even find any R on Aleph30 original design of "Pass Aleph 30 Owner's Manual", it's only 6x10mF without mentioning voltage rating. I think that CRC design came up on FirstWatt line seriesI think that R should be 0R1, using 3 parallel 0R3 5W is my choice |
#38 | |
Sorry,i have too a 22-0-22 Vac trafo with crc psu filter 2x22000uF (40vdc) 0.33ohm 2x22000uF (40vdc) for one only Rail on the output of psu i have about 27Vdc for each rail. Please is ok this working voltage? If no please can you give me some advice about it? I think I should enhance the resistor of the crc can you confirm the value and the power of this resistor? I think 1 ohm 10w should be ok. I also think the ripple should be ok with these values of CRC. Thanks in advance. Last edited by tonimxp; 30th March 2012 at 01:25 PM. Reason: incomplete |
#39 | |
decrease that R to 0R15 or 0R1
#40 |
| Brian GT Aleph and PS boards | mattattnet | Swap Meet | 2 | 17th September 2011 02:10 AM |
| Axials for C1/C2 on SSE? | dr0ss | Tubelab | 5 | 28th August 2010 08:50 AM |
| Aleph 5 with Brian GT boards. (help) | edoirt | Pass Labs | 11 | 31st July 2006 05:15 PM |
| C1 and C2 in BoSoZ | ruangrit | Pass Labs | 3 | 29th January 2003 03:06 PM |
