#21 |
reference to sch in first post of this very thread.
R10 is , say, bleeder for (un-needed) input cap
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#22 |
#23 | |
Are you sure that your considerations about c1 and r1 are correct also for the balance use of the amp? If yes.. for you, why Mr.Pass had used this items ? Thanks in advance. |
#24 |
- yes ; see Babelfish J sch
- foolproof reasons
#25 |
[QUOTE=Zen Mod;2965917
- foolproof reasons[/QUOTE] but from you advice, that is, remove C1 and R10, would not seem so foolproof , why precisely, Mr. Pass, designed the circuit with these two components,,, is not it?
#26 |
because of possibility that his amp is going to buy some ignorant bstrd , eager to connect it to source with some DC on output ?
#27 | |
perfect, now it is all clear, except for a small doubt that inquiries concerning R10, that is, if you Elima this resistance, you do not create an imbalance between the two half-waves of negative and positive, the audio signal? I say this because I see that on the input signal positive there the resistor network formed by R1/R2/R3 and negative input is formed by the resistive network R9/R10. thanks for your patience.
#28 |
#29 |
is it save to use 25V cap for Aleph30 power supply? I was going to purchase in PCX for nichicon super through 15.000uF 50V, but when I look at MUNDORF M-Lytic AG @25V with cheaper price, it's a huge improvement on cap bank capasitance size. need your advice.
- Nichicon ST -> 8 x 15.000uF 50V @$27 = $216 (total 120.000uF) - Mundorf Ag -> 12 x 47.000uF 25V @$17 = $204 (total 564.000uF) I find that papa is using 25V caps on his F5
#30 |
enough said .
xformer secondaries - 2x18Vac
| Brian GT Aleph and PS boards | mattattnet | Swap Meet | 2 | 17th September 2011 02:10 AM |
| Axials for C1/C2 on SSE? | dr0ss | Tubelab | 5 | 28th August 2010 08:50 AM |
| Aleph 5 with Brian GT boards. (help) | edoirt | Pass Labs | 11 | 31st July 2006 05:15 PM |
| C1 and C2 in BoSoZ | ruangrit | Pass Labs | 3 | 29th January 2003 03:06 PM |
