#121 |
Greetings to all! Anyone have any suggestions for me before I mount the pcb? For example I'm thinking of replacing C4 with 15pF directly,so..i can save my time and i can not remove it all over again.
Are you agree with me? Thanks in advance. ![]() P.S. On the bottom Pcb as showed First Wima 0.1uF + Ero 1860 0.01uf are in parallel with C2 220uF Silmic II Second Wima 0.1uF is in parallel with C3 220uF Nikicon Muse Last edited by tonimxp; 2nd May 2012 at 01:55 PM. |
#122 | |
If you want to play with the amount of feedback and change the feedback R, you need to re-check the 10Khz sq wave to see if the comp cap value is still correct. Do you have a scope? |
#123 | |
#124 |
Hi to all!Today i have just start up my aleph 30. I think could be interesting some pictures.
Will be shown in order: 1) square wave test at 10 khz 2) supply voltages of one psu (my amp is a dual mono topology) 3) supply current of one psu (my amp is a dual mono topology) 4) control of the temperatures of the first cooling fin and then on the body of the MOSFET 5) check of the waveforms with tone at 10 kHz (I found 0.14 Vrms)and 100 kHz (I found 0.10 Vrms) sinusoidal,i think there is an attenuation of 3dB (Nelson says there should be about 1.5 dB). 6) I also detected a ripple voltage of 0.04 Vrms ( nelson says 0.3 Vrms but mine is a dual mono psu with uF 176000). Do you have any suggestions for the frequency response slightly deficient on high? Thanks in advance. |
#125 |
I remember you that i had changed C4 (10pF) with 15pF value for square wave test.
Any suggestions? Thanks. |
#126 |
leading edge/corner is rounded
try again with 10p just for splittin' da hair sake
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#127 |
Banned
Just bloody listen to it you lunatic.
How perfect do you need that square wave? ![]() Very nice work |
#128 |
#129 |
#130 |
| Brian GT Aleph and PS boards | mattattnet | Swap Meet | 2 | 17th September 2011 02:10 AM |
| Axials for C1/C2 on SSE? | dr0ss | Tubelab | 5 | 28th August 2010 08:50 AM |
| Aleph 5 with Brian GT boards. (help) | edoirt | Pass Labs | 11 | 31st July 2006 05:15 PM |
| C1 and C2 in BoSoZ | ruangrit | Pass Labs | 3 | 29th January 2003 03:06 PM |
