F5 Semi-Turbo with Lateral Mosfets...
Old 20th June 2012, 09:50 PM   #31
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by tinitus View Post
I expect you have found it by now
btw, it was our good man Juma with the thread 'F5 meets Buzquito'
now that I think about it, he might have inspired Nelson to design the new F5 like frontend/driver for the BA3
let's just say that some things are boiled water for Curl , Borbely and Pass .
in whatever line-up you line them
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st June 2012, 04:06 PM   #32
juma is offline juma  Germany
juma's Avatar
Originally Posted by Paulv View Post
... the bias jfet:2.4 mA...
Sorry, but that way you'll make a popular mistake known as "starved JFETs" which is manifested through grainy & murky sound. To correct it, go for JFET's Id = 70-90% of Idss.
Old 21st June 2012, 10:48 PM   #33
Paulv is offline Paulv  France
thanks Juma, I am on the learning curve, reading lots of threads here and playing with LTspice, hoping that simulation is not too far from real life, I know that I will have to experiment, maybe audiotester (another unknown tool) will tell me if I am right,
I have an old scope too, but dead signal generator....
I think I will opt for a VAS circuit, with BJT(15mA bias),
Laterals, double die 150...500mA bias
looks more stable, less concern with thermal compensation
Thanks to all here, the following schematic owes to you too Juma
Paul
(and sorry if I should not post in Pass Lab)
Old 21st June 2012, 11:20 PM   #34
Default and the fft analysis
2 volts RMS output (first watt )
9 V RMS
18v RMS
if it could only be true!!!!
Old 22nd June 2012, 01:03 AM   #35
fab is offline fab  Canada
fab's Avatar
If you look closely at his schematics of post #23, the source resistors are 10 ohms which is clearly within the 80-90% Idss range. The 2.4ma that he indicates may be simply its spice model of Idss of 3ma or so.
However, in Paul post #33 he made the mistake with 22 ohms as source resistors..
Maybe it gives about 50-60% Idss or so thus is it so bad?
Old 23rd June 2012, 03:56 PM   #36
fab's Avatar
Paul
Hi Paul
The bias of the output mosfet is depending on the VAS current in this type of configuration thus voltage across your 120 ohm resistors. Depending on your LAteral mosfet VGSoff, the VAS may have to be quite different than 15ma. In order to keep at least the 15ma, you may have to change the 120 ohm value.
And for the VAS transistors, the ones you have selected are quite good for this job. However, if you compare with a mosfet VAS you will find a drastic change in the sound (more "alive", if I try to describe it...) although the electrical performance is worse than with good BJT in VAS (as you indicate also more stable in temperature). Some may like it more with good mosfet VAS (like me) or not. It is a matter of taste here..
Fab
Old 23rd June 2012, 05:28 PM   #37
juma's Avatar
Originally Posted by fab View Post
If you look closely at his schematics of post #23, the source resistors are 10 ohms which is clearly within the 80-90% Idss range. The 2.4ma that he indicates may be simply its spice model of Idss of 3ma or so....
I think that current through input JFETs in that sch. is determined by J3 and J4 (they both act as constant current sources).
Old 23rd June 2012, 10:43 PM   #38
fab's Avatar
My mistake Juma, of course you are right.
F5 Semi-Turbo with Lateral Mosfets...Hide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 with lateral mosfets kacernator Pass Labs 2 2nd July 2011 01:00 PM
