F5 Semi-Turbo with Lateral Mosfets...
Old 19th June 2012, 01:24 AM   #21
fab is offline fab  Canada
fab's Avatar
Originally Posted by Paulv View Post
main difference with -f5-meets-buzquito:
R14 R16, ( i like this trick!)
exact resistor values to be detrermined
with 2sk2013 2sj313 if I can get them
psu 32 volts plus 5 volts for drivers
and cascodes for jfets
thanks for your help
comments welcomed
cheers
Paul
Hi Paul
Your latest schematics does not really fit in this thread but more in the f5-meets-buzquito thread if it is no more common source output stage. ...
Old 19th June 2012, 01:41 AM   #22
fab's Avatar
here are more thinking:
R7 and R10 to smooth dissipation in M3 and M4 (values to be determined with CISS rise with lower voltage across M3 and M4) advice welcomed
R14 and R16 with CTN to adjust bias independently of gain
R24 and R4 to choose / balance gain of devices
notice high value of R5: 47k! with C2 forms a low pass and seems to give very good results in LTSPICE on square signal 100kHz with C1 (much less noise on fft analysis and no overshot!)
I took M3 M4 IRF9640 IRF530 available in LTSPICE, I read with interrest f5-meets-buzquito and would like to find the best compromise: not obsolete, VGSoff>2volts, low power TO220?... and probably mount them on a small independant dissipator... R1 and R9 could be 100 ohm or more in a linear region.
as for OLG / NFB ... and linearity I am a newbee I do not know where to go!
and SPICE is not real life, shure we are all aiming for the best, that's the magic of this site!
cheers
Paul
Hi Paul
R7 and R10 just limits the possible voltage swing of the stage. Just use a proper dissipator instead...
Your input low pass filter is for 15392 Hz
The p-mosfet I indicate in the first post schematics are readily available and have a VGSoff of 3 to 5V (TO-220) which is what is required. The IRF device are not the best device for linearity...
For R1 and R9 you want a medium current to drive the output mosfet and operate in the more linear current portion of the medium power mosfet transistor... so you should stay with a lower value than 100 ohms... Again, see the first post schematics.
For the OLG/NFB, my goal is to obtain a similar one as the original F5 thus the schematics of first post...
Fab
Old 19th June 2012, 04:19 PM   #23
Paulv is offline Paulv  France
Default and the winner of the day is....
Thank you Fab for your interrest and support
this one will remind you something!
seems to work very well on square signals: no overshot with 1uF on output,
real JFET would be : 2N5462/5459, unless you suggest differently...
OLG: about 48dB /1pair/8Ohm , will need two pairs of laterals for bass channel (4Ohm)
not too sure about temperature compensation, main concern is with input jfets
the bias jfet:2.4 mA/1...4 volts so less heat than inputs, reduce cascode voltage...
or elaborate some sort of compensation or automatic bias, thermistor will not help much IMO.
cheers
Paul
Old 19th June 2012, 04:35 PM   #24
R.I.P.
A question or three:
I see the cascode resistors R10 & 18 tied to Signal Ground.
Q1.) would the circuit still operate properly if these two resistors were detached from Ground and just connected to each other?
Or
Q2.) do each of the cascodes need to be referenced to a ground to operate properly?
Q3.) would performance deteriorate if these resistors were tied into Power Ground?
regards Andrew T.
Old 19th June 2012, 04:58 PM   #25
hello andrew
I did not intend to design anything special for R10 18, just rushing the drawing...
Q1 I would say yes, some people do it, I think use one 10k res and one cap for same result, but please take advice from other people as well!
Q2 IMO: no
Q3 as long as you use a good decoupling cap, i should work ok
... I'm no professionnal, other people will certainly be more competent
Paul
Old 19th June 2012, 05:31 PM   #26
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hey, btw, another member did this too, but right I cant remember much more
and another btw did you think of BA-3 with laterals instead of F5 ?
Old 19th June 2012, 05:36 PM   #27
oups
Q2: cascode is a mean to reduce the voltage on jfets, and reduce internal capacitance effect, and helps with PSRR, so you only need to have the bases of the transistors to a stable and filtered voltage.
Old 19th June 2012, 05:42 PM   #28
BA-3? what is it?
everyone seems to like F5, I like it's simplicity, at least I can understand !
and not too complicated to build.... except the "plumbing": dissipators, PSU...
Old 20th June 2012, 07:18 PM   #29
BA-3?
I expect you have found it by now
btw, it was our good man Juma with the thread 'F5 meets Buzquito'
now that I think about it, he might have inspired Nelson to design the new F5 like frontend/driver for the BA3
Old 20th June 2012, 09:46 PM   #30
guess Im as good as dead now
F5 Semi-Turbo with Lateral Mosfets...Hide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 with lateral mosfets kacernator Pass Labs 2 2nd July 2011 01:00 PM
