Hi all
I come to this forum because here are more kind to me. I need to know which is more stable circuit, DC offset, and thermal. It's for a 25W Class A amplifier. Thanks a lot Johann Last edited by popilin; 20th March 2012 at 04:49 PM. |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Thermal stability depend of the low frequency gain between the thermal sense (Vgamma multiplier) and the output transistors, and the thermal coupling. The bigger the last, the better stability. Appear that circuit #1 has more DC gain.
LW1DSE |
#3 |
Hi Osvaldo
Thaks for your feedback, but cicuit #1 has the Vbe multiplier at the base of the transistors, can it helps with DC offset? Best regards Johann |
#4 |
The one and only
It seems unnecessarily complex. I think you could eliminate the Q4 Q4
stage altogether and just use the Mosfets to driver the output followers.
#5 |
Hi Mr. Pass
I am honored by your support, but I attempted to do so a few months ago, and the square wave response was so bad. Note that cascodes are yours. What do you think about DC offset stability? +/- 40V come from a regulated power supply. Thanks a lot. Johann Last edited by popilin; 20th March 2012 at 08:57 PM. |
#6 |
I forgot to mention that the voltage amplifier is valvular and has little current capability to drive a MOSFET properly
![]() Thanks again Johann |
| Tube Preamp L&R Channel different current draw | tube cadet | Tubes / Valves | 0 | 21st January 2009 12:37 AM |
| Current mode amp & speakers? | AndyC_772 | Solid State | 7 | 29th April 2007 09:06 PM |
| Voltage amp mixed with current amp? | kubeek | Solid State | 3 | 27th June 2006 07:36 PM |
| Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? | sardonx | Chip Amps | 18 | 19th March 2005 12:23 PM |
| GC current amp & tweeter | pro | Chip Amps | 0 | 7th December 2004 09:38 AM |
