F5 bias
F5 bias
Old 20th March 2012, 02:22 PM   #21
gadut is offline gadut  Indonesia
gadut's Avatar
Originally Posted by AndrewT View Post
24 off 15mF for two channels could be arranged
CRCLCCCC per channel per rail
haha..should I use 2.2mH? more cost for extra caps already paid so much for those 12 caps..24 caps will kill my pocket
got these caps with lower price in local store, around $16.5/pcs
2 X NICHICON KG GOLD TUNE 15000uF 63VDC CAPACITOR!
Old 20th March 2012, 02:26 PM   #22
a.wayne is offline a.wayne  United States
Sin Bin
Why so many caps, why not 12 of 30mf and what size inductor ...?
Old 20th March 2012, 03:02 PM   #23
andRookie is offline andRookie  Norway
Originally Posted by AudioSan View Post
it's not double current. more like 30% rise.
ripple is 3.59A eatch cap.
It is the rippel voltage on the output of the powersupply he is concerned about. If you download PSUD2 you can model the rippelvoltage and see what happends when the current draw rises.
Old 20th March 2012, 03:36 PM   #24
R.I.P.
Originally Posted by gadut View Post
nice build, can't wait to start mine anyway which one is better configuration, CCCC R CC or CC R CCCC ? but it's for my aleph30 with 2pcs talema 2x18V 225VA and 12pcs 15.000uF, so each channel will be supplied by 90.000uF which already exceeds aleph30 design which is 60.000uF per channel
Because I read this to mean he proposes to use 12 off 15mF per channel.
regards Andrew T.
Old 20th March 2012, 03:38 PM   #25
R.I.P.
Why 2m2H?
what's wrong with the same wire resistance as that first R, try 0r2.
regards Andrew T.
Old 20th March 2012, 03:53 PM   #26
gadut's Avatar
Why 2m2H?
I proposed to use 12 off 15mF for both channel
I'm using 3x0R3 5W parallel to get 0R1 15W for each R series, and I find that common CLC aleph psu design in kk-pcb use 1.8-2.7mH. so what's your suggestion on L value?
Old 20th March 2012, 04:08 PM   #27
R.I.P.
9m of 1.4mm diam copper gives ~0r1 and when wound 8T/Layer and 9Layers (75.8T) on a 27mm diam spool results in ~0.2mH
Total heat in that coil would be ~300mW @ 1.7Adc
so back to Jacco's suggestion
CRCC or CLCC
regards Andrew T.
F5 biasHide this!Advertise here!
new f5 bias problem crazycody1993 Pass Labs 40 23rd May 2015 01:50 AM
Weird F5 bias issue JZatopa Pass Labs 21 25th March 2015 03:36 PM
Initial setting of F5 bias--help, please! CanAm Man Pass Labs 30 23rd June 2014 01:12 PM
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 Bias Problem maartentje Pass Labs 150 3rd August 2012 11:10 AM
