What causes reduced spatial ambience?
Old 19th March 2012, 11:55 PM   #11
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
try to decrease OLG of your J2 , and listen is there difference you need
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th March 2012, 12:00 AM   #12
a.wayne is offline a.wayne  United States
Sin Bin
After comparing prices too ................
Old 20th March 2012, 12:50 AM   #13
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by Nelson Bass View Post
So... What can cause the reduced spatial ambience? Feedback? Capacitance in PSU?
IMO
Phase response and armonics and speed
not gettin in to which one is best as it is all a mater of taste.
Whit what records
? Tried Masterpiece the Temptations ?
can you tell where the band is positioned how tall they are when hand clapping.
Figure up 2 guitars say Fender or Gibson tuned exactley to same note do they sound the same?
No they don't is all down to wood how they are built how the pick ups are wound and so on the note is exactley yhe same frequency so what change?
Which one is better? no one just do things a different way for different taste
IMO
Old 20th March 2012, 01:13 AM   #14
labjr is offline labjr  United States
"What causes reduced spatial ambience?"
Not enough drugs.
Old 20th March 2012, 02:25 AM   #15
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Lord of the SIT sez:
In the case of the J2, try removing the Source resistance on the bottom
Jfet and then lowering the amount of feedback. Easiest place for that is
increased value of the feedback resistor from output to (-) input. Make the
input resistor to ground for the same value if you are running balanced.
Don't forget to re-adjust the DC offset.
6 dB more super-happy-fun gain!
Old 1st April 2012, 11:42 AM   #16
holminator is offline holminator  Norway
Jfet
how will this mod affect the f2j?
Old 2nd April 2012, 10:04 PM   #17
The one and only
Similar effects.
Old 2nd April 2012, 10:33 PM   #18
john dozier is offline john dozier  United States
john dozier's Avatar
I want some effects ala LabJr. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 18th August 2012, 09:57 PM   #19
generg is offline generg  Germany
generg's Avatar
Yes i did it.....and i like it! I choose 150k for the feedback resistor.
I even replaced the the chain of the drain resistor of the lower SS and the source resistor of the upper SS (around 0R8) by a chain of 8 0R1 resistors and changed the node where output and feedback connection meet step by step...
Sound change was interesting, but Helas! I liked the masters point most!
And the omitting of the source resistor and loosening the feedback was more important for the sound improvement finally.
and the First Wtt is......a really First Class PSS Idea
Old 21st August 2012, 02:59 AM   #20
The one and only
There is an important DIY point imbedded here, which is that given the
particular sound of an amplifier (or other component) there are often
inexpensive ways of adjusting it in a particular direction. I happen to
have known the answer through experimentation, and the J2 sound
was a particular choice, but not the only one available.
Contrast this inexpensive approach with "Recap everything with the all
new Vera$$ity mk 4 teflon$, replace all the wire with 99.999999
gold filament$ wound helically around organic $paghetti noodles boiled
in $quid ink and align the magnetic pole$ of the transformer to the center
of Orion'$ belt during the $olar eclip$e"
What causes reduced spatial ambience?Hide this!Advertise here!
Spatial Inc preamp amolas Solid State 18 12th June 2012 07:20 AM
Spatial Quality, Hall Sound, Soundstage, ASW & LEV ZilchLab Multi-Way 46 28th March 2011 05:50 PM
The copy of the spatial sonic field syntheticwave Everything Else 0 2nd January 2011 03:03 PM
Ambience tweeters? Audiophilenoob Multi-Way 13 20th June 2005 02:38 AM
Copyright ©1999-2017 diyAudio
