F5X -- the EUVL Approach - The Build Thread
Old 31st January 2014, 10:34 PM   #841
JBdV is offline JBdV  Netherlands
I got the message Patrick, Thanks!
Old 3rd February 2014, 06:36 AM   #842
johnwmclean is offline johnwmclean  Australia
I found time today to troubleshoot and fix my protection and regulator boards, I now have CRegC up and running.
I also have a new pair of PMC twenty 22ís sounding particularly excellent.
Thanks to Patrick, Mark and Xen audio.
My finished amp... CRegC... Yeah Baby!
Old 3rd February 2014, 07:34 AM   #843
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Wowww... Congratulation johnwnclean
As far I can see from your picture is a very clean build!
This week I will receive my box! Yeah... I can't wait more
Enrico
Old 3rd February 2014, 09:10 AM   #844
EUVL is offline EUVL  Europe
Firstly congratulations to John.
I would like to see :
a) a few more pictures of the internal layout and wiring
b) some temperature measurements on the heat sink, regulator sink, .... etc. vs. ambient
c) voltage and bias info after regulator
d) subjective descriptions if SQ.
Otherwise very well done.
Patrick
xen-audio.com
Old 3rd February 2014, 09:29 AM   #845
a.wayne is offline a.wayne  United States
Sin Bin
I also have a new pair of PMC twenty 22’s sounding particularly excellent.
Wow , what a sweeet build , what are the internal sinks for, Diodes ..?
Old 3rd February 2014, 10:51 AM   #846
Patrick
No problem, Iíll get organised and post this up in the coming week.
Rectifier diodes as well as the regulator MOSFETs.
Old 4th February 2014, 04:01 PM   #847
Nikon1975 is online now Nikon1975  Austria
OK, time to give some feedback:
I started this project end of 2010. Since then I got into a major earthquake, a nuclear disaster, a change of country and a new baby. I basically stopped any DIY since the beginning of 2012 due to extensive travelling, beside the minimal necessary to convert all my electronics from 100V to 230V. At one moment I thought I would never complete this and any other probject, at least for a while.
Anyway I put a quite some effort in it and many of you have at least some components of this built that passed by my desk, so in Christmas I decided to risk my marriage and complete the project (Actually jokig, as my wife was almost supportive). Being away for so long I was feeling kind of rusty and a bit lost, so apologize for the silly questions I asked.
If you think soldering SMD component is tricky, you should try to do it while a child is pulling your elbow :-)
This to say that I have even more reasons to be happy. Now back to business for some electronics and I would like to give some, very personal tips to who is starting to build:
1) It is not strictly necessary, but if you have the possibility get the following tools: lab power supply able to do +-20 V 4A , a flexible screwdriver and a dummy load for the power supply a big magnifing lens with light. A varia would not hurt.
2) The audio part for me worked very well at the first try, although I put the bias a bit too high (The sound was good though). I started with 1.8 A with only the heatsink, but it claimbed to 2.2 A when everything was assembled. So I would aim for something like 300 mV drop on the 0.22 ohm resisistor. I found very VERY useful the tip given by Nic to assemble the audio board without the mosfet, connect the lab PSU and dial 2.15 V of GS. This gives you a much easier setup.
3) I did not use the dummy load but I should have had, as I have transformer with 16 V and not 15 V as prescribed. After some playing with the TL431 I decided to try my luck and installed a 22 V Zener, that gives me 16.0 V and 15.7V for positive and negative supply under load. The input of the regulators is around 18.5V.
4) I got a bit in trouble with the control board. I assembled everything in one go and this was a mistake. So I removed all the IC (I was confident that the other components were OK) and started from control and then adding one relay driver at a time. Like this I could check where the problem was step by step. At the end it worked. (Hopefully will continue to work). I had a silly problem with it that I will report as it took me some thinking to understand. I had one plastic washer of the to-220 device that got damaged, so that the chassis was at 12 V potential. This got undetected for one week, until I decided to complete everything and install the chassis grounding. After that it was happening that when I was connecting the DAC, if I was connecting only one channel (no matter which) everything was OK. If I was connecting both channels the DC protection was tripped. This was happening even with the amp in off state, so with input shorted. After scratching my head for a while I disconnected the earth from the chassis and I could measure 12 V: the problem was obviuos. I managed with a bit of patience and a tool I produced to unscrew the front panel without removing the PSU and fixed the condition. Now is everything as it should be. By the way, my protection board trips at 1.5 V.
I also got a bit in troubles with the mechanical assembly, partly due to the luck of connectors that is specific of my build, so follow the instructions.
I like the sound very much, I have a F5 with Toshiba outputs to compare with and the control and tightness improvement is easily detectable. I'll need to make some more listening when the ground floor of my flat is low, meaning everybody is out (Today's childern toys are a nightmare !!!)
I was thinking about deriving the wires from the push button and to have the preamlifier pushing the buttons for me. It would be easy to implement with a microprocessor.
About temperatures. This was another silly problem as my lab is in the wintergarden and it is consistently 5-6 degree colder than the living room, so I had to do some back and forward few time.
At 2.2 A and ambiet temperature 26 degree the main heatsinks were at 70 degree max 65 degree on the side. The regulator spot on the cover arounf 67. Now I have 63 degree max and 58 min, I think the bias is around 1.8A, but did not really measured it. I think that the grids below the amp really affect the dissipation of the regulator, so if the regulator is too hot you may leave the off. Also if you elevate a bit the amp, leaving more space between the heatsinks and the table, this will increase air circulation. Anyway I am kind of happy now, I will check again when summer comes. (At thet time my lab will be 10 degree hotter than the living room).
The DC offset is consistently below 1 mV.
Good listening to everybody !!!
Davide
Old 4th February 2014, 04:32 PM   #848
Many congratulations. Glad you like the result, which is most important.
Then you are not regulating but just running as a cap multiplier.
You should at least have a drop of 3V across the regulator, and that gate of the MOSFET should be about 2.5~2.8V above the desired output.
If you study the circuit, you will also know that the gate voltage cannot be higher than the input voltage.
So if I were you I would use a 18V Zener, or lower.
And you should use an oscilloscope to look at the input, gate, and output of the regulator under load to satisfy yourself it is actually regulating.
Also simple enough to simulate in Spice.
MOSFET models were published (by someone else) here in the forum.
I was told by other builders that 1.6~1.8A will lower heatsink temperature without noticeable change in SQ.
So you may consider that also.
Patrick
xen-audio.com
Old 5th February 2014, 08:26 AM   #849
Thanks,
This mistake was induced by NOT using the dummy load. I was expecting a much higher input voltage and I wanted to limit the voltage drop to avoid excessive dissipation. I was surprise as well when I found only 18.5 V in input (I was expecting something between 21-22 V) and I tested the circuit with the lab power supply and the F5X as a load with 21.5 V.
In theory it should not matter much regulation or multiplication at constant current, but I will "fix" it as the regulators are the only part that is easy to extract from the amp.
Davide
Old 6th February 2014, 04:47 PM   #850
One thing I forgot to say: the story about 12 V or 24 V relay is IMHO purely academic, at least for what concerns the signal relays. Looking at the specs the Omron relay is supposed to work between 75% and 200% of the prescribed voltage at 25 degree and between 75 % and 130 % at 75 degree. Additionallt it is stated a resistence of the coil 0f 1028 ohm. So as we have our remperature is around 60 degree, even if we use the 75 degree parameters we have a voltage range between 9V and 15.6 V. If you just with a 1k resistors on the cable your 12 V relay will always be operated in a safe spot. The resistor will dissipate 0.1 w. So I have 12 V relay and I did not bother to complicate the wiring and connect them in series.
If you have different relay check the specs of what you have in term of coil resistance. Basically you need the same value to divide the voltage by two.
Have a nice build,
Davide
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 08:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 04:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 07:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 05:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 05:49 PM
