F5X -- the EUVL Approach - The Build Thread - Page 83 - diyAudio
Old 25th January 2014, 06:51 PM   #821
EUVL is offline EUVL  Europe
Dave,
The basic circuit and hence the description of the protection board has not changed.
There was one PCB layout error, which was described in detail and rectified in Batch 2 PCB.
There were also some slight changes in resistor values of the diff pair to ensure proper tripping, taking into account FET tolerances.
This has also been discussed in the pdf document.
As far as I am concerned, all the relay types you had in your list (Omron G6S and American Zettler) are correct.
They only want to be 24V unless you want to wire both channels in series, as John does.
For the speaker relay, you can pretty much choose what you want, as long as they don't consume too much current.
And the (default) automotive relays are already amongst the most hungry for the purpose.
Patrick
xen-audio.com
Old 26th January 2014, 08:27 AM   #822
Thank you
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th January 2014, 09:08 AM   #823
Mains relay is listed here :
Patrick
xen-audio.com
Old 26th January 2014, 02:31 PM   #824
The assembly looks much better now, so I proceeded with the control board.
I assembled everything except Q6 as I am short of one irf610.
The voltages on the board are correct in all the places I could check, but the board does not show sign of life when I push the button. Any hint what I can start checking?
Thanks,
Davide
Old 26th January 2014, 03:41 PM   #825
How long have you waited for the start-up ?
Try to understand the functionality and start with the start-up delay flag.
Patrick
xen-audio.com
Old 27th January 2014, 11:06 AM   #826
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Default F5x - I got the last available
Hi to all of you in this thread,
Today I received from Mark the tracing number for the shipping of my F5X .
First of all a big THANKS to Mark and Patrick to support me with the last available GB2 plus the resistor and the Mosfets for the CRegC.
Now is time for me to start collecting all the parts and I would like to ask your some advise for the main transformers. Reading the dedicate GB I am oriented to place the order to Toroidy-Poland but maybe someone has another great supplier in Asia?
I the meantime am reading again the Potential GB where the various connectors have been discussed already trying to understand which one you choose at the end. If I have some doubt I will request your help again.
Thanks for your help and Best Regards,
Enrico
Old 27th January 2014, 02:52 PM   #827
Dear All,
I could not find in the local shop the irf610 I am missing for the control board (Q6), but I have the following:
Irf 540
Irf840
Buz73
I guess that the first one should be my best choice. Correct?
Thanks,
Davide
Old 27th January 2014, 04:50 PM   #828
I think something is not right with my assembly of the control board. The led cycle, but with the sequence off-blue(R47)-red(R46).
The status of the output does not change, they all stay off beside rsr2 that after the delay goes on and stay like that. Jumper do not seem to affect this behaviour.
Any hint?
D.
Old 27th January 2014, 07:25 PM   #829
Any TO220 FET will do, only for switching, and no speed requirements.
And you probably did not make the Batch 1 PCB correction as described by Alexis.
Please take your time to read some of the posts when you were in your passive phase.
A lot of your recent questions would have been answered, and you would have known more.
You are almost there, so no need to rush.
Patrick
xen-audio.com
Old 27th January 2014, 07:28 PM   #830
Transformer for Asia is VERY difficult.
Mark has his F5X transformer shipped by SumR, and the shipment was as expensive as the Tx.
WK recently had 2 from Toroidy, but only because someone hand carried for him from Germany.
You should try to source in Korea first.
If not, then you are probably stuck with Chinese suppliers.
Unless you also have someone to hand carry from Italy.
Patrick
xen-audio.com
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
