F5X -- the EUVL Approach - The Build Thread
Old 13th August 2013, 03:20 PM   #681
Horio is offline Horio  United States
Horio's Avatar
pmchoong,
I did the board repair since I was part of the first batch (same as yourself). I posted a couple of photos of the finished product here.
Regarding the replacement resistor values, I exchanged a few posts with EUVL here. The repair works great, and I the DC detection/protection works as expected.
Old 14th August 2013, 07:50 AM   #682
R.I.P.
Horio,
both links take me to post651 !
Where should each link go to?
regards Andrew T.
Old 15th August 2013, 03:23 PM   #683
Horio's Avatar
Really? I just clicked on them both, and they went to different locations. First link should go to post #613 showing photos of my populated and fixed protection boards. Second link should go to post #601 talking about the revised SMD resistor values.
Old 15th August 2013, 03:27 PM   #684
bkdog is offline bkdog
Works as advertised for me. Many thanks for the update and info Horio.
Old 15th August 2013, 03:45 PM   #685
pchw is offline pchw  United States
This symptom has something to do with the preference of number of posts per page. The link uses the page number based on Greg's preference. The software doesn't always convert to the correct page with the reader's preference.
- Fred -
Old 17th September 2013, 01:38 AM   #686
alazira is offline alazira  United States
alazira's Avatar
Regarding the regulator, are 1/10W resistors ok at R1/R3?
Old 17th September 2013, 08:29 AM   #687
R.I.P.
Ala,
what current flows through each of those resistors?
Then determine the dissipation.
Compare that dissipation to Pmax. Aim for <<50%, preferably <10%
regards Andrew T.
Old 17th September 2013, 10:21 AM   #688
EUVL is offline EUVL  Europe
Say at start up C2 is empty (0V).
R1 sees full rail voltage (say 22V when not loaded)
In the second or so when C2 (and later C3) gets charged, R1 sees :
22*22/1k = 484mW.
Yes, only for a second or so.
But why take any risk ?
Patrick
xen-audio.com
Old 17th September 2013, 07:02 PM   #689
alazira's Avatar
22*22/1k = 484mW.
Patrick
Thanks Patrick,
I have some PRP 0.1% 10ppm, but then I find that they are 1/10W, not the usual 1/4W ones. In any case, looking at your calculation, perhaps I will use 1/2W ones, even if only for psychological comfort
Old 18th September 2013, 04:28 AM   #690
It is not in the signal path, so just use any decent 2x7mm metal film.
Vishay Dale CMF55 or Vishay Beyschlag MBB0207 1%, e.g., are rated at 0.4W.
I think the PRP 0.5W may be too large to fit PCB.
Patrick
xen-audio.com
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
