F5X -- the EUVL Approach - The Build Thread - Page 62 - diyAudio
Old 16th June 2013, 12:53 AM   #611
alazira is offline alazira  United States
alazira's Avatar
Can someone advise me on how to calculate the power requirements for the bridge diodes in this amp? I have some 15A rated ones I would like to use but want to know if it will be sufficient.
Old 16th June 2013, 04:03 AM   #612
EUVL is offline EUVL  Europe
Yes, 15A is sufficient.
What is the part number ?
Patrick
xen-audio.com
Old 18th June 2013, 12:52 AM   #613
Horio is offline Horio  United States
Horio's Avatar
Not bad for an amateur SMD guy:
Good liquid flux, tweezers and braid really helps.
Old 18th June 2013, 12:54 AM   #614
Excellent.
Patrick
xen-audio.com
Old 18th June 2013, 01:35 AM   #615
alazira's Avatar
Patrick
VS-15ETH06FPPBF
VS-15ETH06FPPBF Vishay Semiconductors | Mouser
http://www.mouser.com/ds/2/427/15eth06p-87399.pdf
There is a 30A version, but it doesn't come in an isolated tab package.
Old 18th June 2013, 01:46 AM   #616
Specs looks OK. Should work.
Patrick
xen-audio.com
Old 26th June 2013, 11:05 AM   #617
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
Hi Patrick,
Finally with full load the voltage after CRC is 18.1V.
A dumb question, I don't have clear what is the right polarisation current per device. Now I have 333mV across the 0R22 resistor (Measured after two hours) (1.5A per device / 6A per channel). I read on the thread that the right value is 2A per mosfet. But with 1,5A my amp is hotter than hell . (6 seconds by hand test, ambient temperature 32 C) (The top panel is much hotter that the heatsinks).
Am I wrong?
Thanks!
> Before CRC = 21,4V
That is OK.
> After CRC = 19,8V
Difference before and after CRC is 1.6V.
R in the CRC is 0.67R.
So your total bias per balanced F5X is at this moment 2.4A.
Dissipation per FET is 24W per FET, so nothing detrimental will happen.
For optimum output at 6 ohm load, total bias current per channel should be 4A when fully warmed up.
Suggest you check voltage across the 0R22 resistors on the F5X PCB.
To be on the safe side you can start with cold bias (room temperature) of 1.5A.
That means voltage across the 0R22's should be all 0.33V at start up.
And please read Dave's excellent instructions at the start of the thread.
Patrick
Happiness is a warm soldering iron
Old 26th June 2013, 12:09 PM   #618
two times 1.5A does not equal 6A.
What have you built?
What bias have you used?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th June 2013, 12:23 PM   #619
ramallo's Avatar
I'm sorry, I probably would not have explained well. I left every mosfet at 1.5A, 333mV across the 0R22 resistor. 4x 1.5A per channel (A F5X channel have 4 x fets, two for F5 side) Am I wrong?
Old 26th June 2013, 12:41 PM   #620
Wrong.
The bias current passes through both mosfets on one side in series.
It's the same current in the N & P fets.
The other side does the same.
That way your total bias for the two halves of the balanced amplifier is two times 1.5A = 3A of bias current.
If you now add the right and left channels toether you will have the PSU supplying a total current of 6A IF you only had ONE transformer.
Each transformer supplies 3A.
In a standard F5X build the current is 4A.
All the fets were measured and selected for this 4A of current (2A through each FET).
regards Andrew T.
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
