F5X -- the EUVL Approach - The Build Thread - Page 57 - diyAudio
Old 4th May 2013, 06:03 PM   #561
EUVL is offline EUVL  Europe
You can start.
The only change as far as I am concerned is already described in Part 1 of the description.
So you should use those revised values in the diff pairs.
There is ONE error in the PCB which you need to rectify first before soldering anything.
But that has also been described, and tried out by Nic.
If in doubt ask Nic, or Alexis.
Alexis promised me again to write the build and test section.
He deserves the chance as far as I am concerned.
Patrick
xen-audio.com
Old 8th May 2013, 05:08 AM   #562
Someone asked by PM where to get Kerafol for 2SK1530 / 2SJ201.
As far as I know, only Zhou Fang stocks them.
Anyone knows an alternative source ?
Patrick
xen-audio.com
Old 8th May 2013, 07:56 AM   #563
Markus is offline Markus  Germany
I am currently preparing for testing my first protection board and I am wondering how to handle the molex connectors. Soldering the headers on the board is not an issue at all but I am not sure how to handle the wire side. From all what I have found so far this microblade connector needs a quite expensive crimp tool to connect the wires
0638190100 Molex Inc | WM9020-ND | DigiKey
Could somebody give me a hint if I am wrong or if there are other/better alternatives?
Markus
Old 8th May 2013, 09:42 AM   #564
The Dastardly Dad of Three
Patrick
someone posted this link:
Warmtegeleidende folie Keratherm - Rood 86/82 Kerafol 86/82 (l x b) 100 mm x 100 mm Dikte 0,25 mm 6.5 W/mK in de Conrad online shop
Old 8th May 2013, 11:34 AM   #565
Just crimp by hand (long nose pliers).
Patrick
xen-audio.com
Old 8th May 2013, 02:35 PM   #566
heinz1 is offline heinz1  Europe
I haven't looked at this in detail yet, but one might be able to identify the appropriate connector/(cheap !) crimping tool combination here (Don't be shocked, that's a somewhat messy "old style website"):
Crimpen
The owner specializes in electronics for model making.
Old 8th May 2013, 03:18 PM   #567
MarkLai is offline MarkLai  Hong Kong
Patrick
Yes, long nose plier but with solder.
Mark
Old 10th May 2013, 09:16 AM   #568
All, thanks for your hints.
The crimp terminals are really tiny and at the end they have to fit into the connector housing. So I guess the crimp has to be really "nice" otherwise it won´t fit.
But well, I´ll order the terminals and housings and give it a try.
I´ll keep you informed about the outcome
Markus
Old 10th May 2013, 11:25 AM   #569
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Patrick
Conrad - Ihr Online Shop für Elektronik, Computer, Multimedia, Modellbau & Technik
Old 10th May 2013, 11:09 PM   #570
Patrick
Just discovered in the diyaudio store:
Pack of 9 Keratherm® Insulators - Parts
Conrad has the 86/82 type only in big sheets.
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 08:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 04:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 07:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 05:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 05:49 PM
Copyright ©1999-2017 diyAudio
