F5X -- the EUVL Approach - The Build Thread - Page 45 - diyAudio
Old 21st February 2013, 12:44 AM   #441
Horio is offline Horio  United States
Horio's Avatar
Congrats Nick!
Regarding the protection board, were there any changes you made or was it simply adjusting some of the jumpers?
Old 21st February 2013, 02:19 AM   #442
EUVL is offline EUVL  Europe
Some small layout bugs, and the diff pair in Nic's board is not functioning according to design.
Alexis's worked OK, so we are building a new board from scratch to cross check.
Patience.
Patrick
xen-audio.com
Old 21st February 2013, 06:48 AM   #443
NicMac is offline NicMac  Italy
NicMac's Avatar
So put your trust in my poor soldering skills
As Alexis's worked OK, my soldering skills are so poor that I have even changed the PCB layout
Old 21st February 2013, 02:53 PM   #444
Horio's Avatar
My SMD soldering skills leaving much to be desired. I'm toying around with the idea of buying a SMD rework station and some solder paste, and trying that technique.
Old 21st February 2013, 04:29 PM   #445
NicMac's Avatar
Really not that difficult. Thin low melting point (lead containing) solder. Flux the board before each component. Thin iron tip. Magnifying glass.
Gain courage with the resistors and caps - then do the chips. For what my advice is worth.
I did also consider a smd rework station, but for that to be better I guess a lot of practice is also needed. I did get a syringe of solder paste, but I can't get it out of there I guess the pro's have some kind of pump
Old 21st February 2013, 05:09 PM   #446
Your words against his. I don't take sides.
And such comments are not particularly productive either, if I may say so.
We shall build one ourselves and find out.
The schematics is correct; 2 people have checked it independently by hand calculation and Spice simulations.
So not design error.
Patrick
xen-audio.com
Old 21st February 2013, 07:45 PM   #447
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
BGA Reballing Station 40 Stencils 80mm 4 Bottles Solder Balls 100g Paste | eBay
something like this maybe??
" If you're going throu hell, keep going"
Old 21st February 2013, 10:33 PM   #448
NicMac's Avatar
Originally Posted by Horio View Post
Congrats Nick!
The jumpers is really a non-issue. You are best served by placing all of them in the ON position (towards the center of the board) to start with.
75% of the jumpers permit you to do things you would never want to do. I don't know why - but the option is there
Old 21st February 2013, 10:46 PM   #449
NicMac's Avatar
Here are a few photos.
To check the correct operation of the board I use LEDs with current limiting R in series. This gives a nice visual readout of relay behavior.
If all the jumpers are in the ON position you will find that all LEDs are ON in the SBY state and OFF in the ON state.
This assures maximum exposure of DC offset to your speakers and no music when the amp is on
Old 22nd February 2013, 01:56 AM   #450
pmchoong's Avatar
Hi Nic,
I see a couple of relay at the speaker terminal and are not in the BOM.
1) Was there a group buy for these?
2) What are the specs?
3) Also the relay at the fuse holder, why do you need this?
4) On the control board, where are the ISR 1 & 2 connect to?
5) Why are the "On" and "Off" positions different on both sides?
On the mute image you posted earlier, I can also see 2 wires going out from the mute board.
6) To where are these connect to?
Thanks.
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
