Old 8th February 2013, 06:23 AM   #411
pmchoong's Avatar
Originally Posted by NicMac View Post
Look in the BOM....
Yes, that was stated in the BOM.
Thanks.
Old 8th February 2013, 04:52 PM   #412
Horio is offline Horio  United States
Newbie
Horio's Avatar
Nic, is your amp making music now?
Old 8th February 2013, 06:32 PM   #413
NicMac is offline NicMac  Italy
NicMac's Avatar
Yes, but one channel at the time and not with its own supply.....
I am fighting with the control board as I want this in before I close up the case.
To my surprise very little biasing was needed after shifting to the H configuration.
2SK1530/2SJ201 sales thread and FET list
Old 9th February 2013, 04:19 AM   #414
pmchoong's Avatar
Hi Nic,
Are you done with the protection board yet?
Old 9th February 2013, 07:38 AM   #415
NicMac's Avatar
Originally Posted by pmchoong View Post
Hi Nic,
Yes - but I cannot make them work as I want.
I'm in contact with ashaw and we are trying to solve the problems together.
I recommend keeping the assembly of these boards on hold for a bit. It is probably just my wrong, but anyway.
Note that the standard jumper configuration posted previously makes little sense for the F5X without regulated supplies.
Old 9th February 2013, 07:44 AM   #416
EUVL is offline EUVL  Europe
The PCB has been tested before and proven to work.
So I am pretty sure it is a solveable problem, if any.
Just some patience while we sort it out.
Patrick
xen-audio.com
Old 9th February 2013, 03:27 PM   #417
Newbie
Horio's Avatar
I will probably wait until you sort out the control board issues with Ashaw before I start assembling mine. When you get the control board up and running as you want, do you mind posting photos before closing up your case? It would be helpful to see the board fully soldered and with the jumpers in place.
Old 9th February 2013, 03:47 PM   #418
NicMac's Avatar
That means I will have to expose my SMD soldering skills in public
Old 9th February 2013, 04:07 PM   #419
Yes, everyone should put their protection board building on hold till Nic has got it to work.
Then we decide how to "repair" for all of you.
Alexis is still taking charge, but I am keeping a watchful eye on it.
Patrick
xen-audio.com
Old 11th February 2013, 03:57 AM   #420
pmchoong's Avatar
Default Fukushima resistors
Are the 24pcs of 1k ohm Fukushima resistors for the CRC boards? We'll be using CRC until the regulator boards are confirmed to be working, correct?
I have done up my control board and waiting for ashaw to provide instruction on testing.
F5X -- the EUVL Approach EUVL Pass Labs 812 14th May 2013 02:25 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright ©1999-2013 diyAudio
