F5X -- the EUVL Approach - The Build Thread
Old 26th January 2013, 01:18 PM   #391
EUVL is offline EUVL  Europe
PCB tracks on the amp board for the MOSFETs are minimum 10mm wide, double layer 70Ám.
That is equivalent to 1.4mm2, but solid copper with a large surface area.
And two conductors in parallel to half the inductance (& resistance).
Patrick
xen-audio.com
Old 26th January 2013, 03:08 PM   #392
Horio is offline Horio  United States
Horio's Avatar
My new toy:
Now I just need to learn how to use it!
Old 26th January 2013, 03:52 PM   #393
Looks good.
One of the things that please me most with this project, despite all the trouble, is how many of you has taken the trouble to learn to build amplifiers properly.
Hopefully that will be the first of many years when you can really enjoy this fastinating hobby.
Patrick
xen-audio.com
Old 6th February 2013, 02:40 AM   #394
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Default Degen resistors and mute board
Please take a look at the images 'Degen resistors' and 'Mute connection'.
On the 'Degen Resistor Image' :
1) Is the regen resitors solder onto these pads?
2)Are the jumpers position for the Q11A, Q14A, Q10A and Q7A correct?
3) Is it okay if I didn't remove the tefron sleeve for the jumpers between Q6 and Q15?
On the 'Mute Connection Image':
4)Does the last hole on the Mute board extend all the way to the amp board or is just extended to the Input board only?
5) The holes right after R103 and R104, where do these goes to?
Thanks in advance.
PMChoong
Old 6th February 2013, 02:49 AM   #395
pmchoong's Avatar
Default 2sk170bl
Hi all,
I brought some 2sk170BL from a local shop and I wonder if they are fakes.
The ones on the left are Nic's and the ones on the right are mine. Are these fakes and how do you tell?
Thanks again.
PMChoong
Old 6th February 2013, 05:43 AM   #396
NicMac is offline NicMac  Italy
NicMac's Avatar
Yes, yes and yes.
The wire does not go all the way to the amp board.
The two holes are the amp inputs and goes to the XLR sockets.
Old 6th February 2013, 05:44 AM   #397
NicMac's Avatar
Fakes in my opinion. Trace them or measure Idss.
Old 6th February 2013, 06:42 AM   #398
I would not say so.
You can have 2SK170BL which have 2.54mm leg spacings (on tape, not in bid).
Mine looks exactly like those on the right.
Only way to find out is curve trace, or measure Idss, then ndegen 5R, 10R, 15R.
And then plot the values to get the curve.
There are enough people with "curve tracers" around.
Patrick
xen-audio.com
Old 6th February 2013, 07:23 AM   #399
pmchoong's Avatar
Default 2sk170bl
Hi Nic and Patrick,
Thanks. I brought these 2sk170BL couple weeks back.... wonder if they refund.
Old 6th February 2013, 07:26 AM   #400
qusp is offline qusp  Australia
qusp's Avatar
they look fine to me
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
