F5X -- the EUVL Approach - The Build Thread - Page 36 - diyAudio
Old 14th January 2013, 07:00 PM   #351
EUVL is offline EUVL  Europe
Test it with 2x 4ohm 100W resistor (one per rail) after the CRC boards, before you test it with the amp.
You can use the scope in ac coupling to check the ripples.
And check the DC voltages at various stages of the PSU.
Patrick
Patrick
xen-audio.com
Old 15th January 2013, 07:49 AM   #352
pmchoong's Avatar
In the BOM for the power supply, it was listed per channel:
D8-D11, - 4 Diode, - 20A Ultra Fast, - STMicroelectronics, - STTH2002D, -
497-5276-5-ND
1) I see 16 nos here and I only have 8 from the GB.
2) Why wasn't a board done for these instead of hand wiring them?
3) It's difficult to see which wire goes into which leg of the diodes. Could Nic be kind enough to sketch out a diagram?
Thanks.
Old 15th January 2013, 07:59 AM   #353
NicMac is offline NicMac  Italy
NicMac's Avatar
There was an error in the BOM and ashaw did not notice it. Therefore you are missing 8 diodes. You have only paid for the 8 you have.
See attachment.
Old 15th January 2013, 08:08 AM   #354
heinz1 is offline heinz1  Europe
There are also some drawings in the .pdf file compiled by Mark Lai called "Xen Audio F5X Amplifier Case Assembly Notes" which was sent to case subscribers.
Old 15th January 2013, 12:34 PM   #355
pmchoong's Avatar
Thanks, guys.
Old 15th January 2013, 03:00 PM   #356
Horio is offline Horio  United States
Horio's Avatar
Originally Posted by NicMac View Post
Just a few pics before I close it up.
Thanks for the progress photos.
I'm still a bit surprised that a little rectifier board wasn't part of the project, considering all the attention paid to the other details of the amp. In the end its not that important, but it certainly would clean up things a bit under the PS heatsink.
Old 15th January 2013, 03:44 PM   #357
NicMac's Avatar
I'm sure that a small PCB will be part of Patrick's final solution for the regulated supply once this is ready.
I actually learned a bit about P2P wiring having to do this and in the end it results very reliable and is invisible being located below the heatsink.
Old 15th January 2013, 04:09 PM   #358
At the time we did this years ago, there was no rectifier board. I used P2P myself.
Also it has been a DIY project, with a lot of your own participation, and not a finished commercial product from me.
Anyway, there is one (PCB) now.
If you want to get organised, WK will get them made and send to the distributors, as before.
You can do direct paypal this time for the small sum.
But don't ask him to send to 30 addresses.
He has already way too much work ....
OK ?
Patrick
xen-audio.com
Old 15th January 2013, 04:58 PM   #359
So we checked PCB prices.
70m copper, double sided, blue mask, white silk screen.
4 pieces per amplifier, 80 HKD (~10 USD) all inclusive (Paypal, registered post, etc.)
Please post at one of the GB threads, and leave this for technical things.
Patrick
xen-audio.com
Old 16th January 2013, 01:28 AM   #360
Horio's Avatar
Thanks Patrick. By no means was I being critical at all. I was just stating my surprise considering the amazing amount of attention to detail you have put into the project as a whole.
For those who are interested, I started Rectifier Board GB interest thread here.
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
