F5X -- the EUVL Approach - The Build Thread - Page 35 - diyAudio
Old 14th January 2013, 09:32 AM   #341
NicMac is offline NicMac  Italy
NicMac's Avatar
16V - I am using a lab supply with adjustable current limit for safety.
I actually did find the time to assemble the transformer cradle, rectifiers etc. last night so I will be using this soon.
Did you happen to find a suitable inrush current limiter thermistor at Digikey?
Old 14th January 2013, 11:09 AM   #342
EUVL is offline EUVL  Europe
> Simply like this?
NO.
Turn round 90. And remove all the jumpers to Gnd, without saying.
And read F5X Preamp Basic Circuit Topology carefully (P.2 of the article).
Patrick
xen-audio.com
Old 14th January 2013, 11:10 AM   #343
The one we proposed is available from DK or Mouser, not ?
Patrick
xen-audio.com
Old 14th January 2013, 11:26 AM   #344
NicMac's Avatar
>NO.
Difficult to remove jumpers from a photo, but of course no connections to Gnd
I actually had it turned around 90˚ first as this made more sense to me. However, electrically I cannot see the difference between these and the X (see drawing below)
I guess I should read it better
Old 14th January 2013, 11:28 AM   #345
NicMac's Avatar
Yes you did, but as I am about to place a Digikey order I was just probing Davide.
Old 14th January 2013, 12:36 PM   #346
NicMac's Avatar
I just realized that heinz1 (in his unofficial BOM) had actually found them (or similar) on Digikey:
50R 6A 570-1109-ND
75R 4A 570-1011-ND
I guess I will take one of each and decide later which to use
Old 14th January 2013, 12:38 PM   #347
You are right.
Any of the above would have been electrically identical.
All the intersections require soldering / electrical connections, without saying.
P.
xen-audio.com
Old 14th January 2013, 01:03 PM   #348
heinz1 is offline heinz1  Europe
One of the thermistors originally suggested by Patrick (Ametherm MS32 50006L) is not available at DK.
MS32 50006 is a non-stock item; minimum order 25: 570-1020-ND
That's why I proposed AS32 50006: 570-1109-ND
Old 14th January 2013, 01:59 PM   #349
Just try.
They don't cost that much.
I also cannot say anthing about those I have not tried.
And you can read datasheet as well as I do.
Patrick
xen-audio.com
Old 14th January 2013, 06:39 PM   #350
NicMac's Avatar
Just a few pics before I close it up.
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
