F5X -- the EUVL Approach - The Build Thread
Old 9th December 2012, 10:02 AM   #231
NicMac is offline NicMac  Italy
NicMac's Avatar
>As with all properly designed protection circuits, the passive state (no power) is the safe state. i.e. muted.
That was what I reasoned.
>However if you also volunteer to test, and soon, contact WK to arrange a set of mechanical hardware to be sent to you. Best to contact him by email.
WK has e-mail. I should have the time in January/February to test.
No comments on my front-end bias? Just curious.
Nic
Old 9th December 2012, 04:01 PM   #232
EUVL is offline EUVL  Europe
What are the Idss of your JFETs ?
Patrick
xen-audio.com
Old 9th December 2012, 04:21 PM   #233
heinz1 is offline heinz1  Europe
Two minor errors/additions in the BOM:
- R45, R46 (Susumu 0805 SMD, 5.1 R): The BOM claims four of these per channel, but in the schematics and on the board, there are only two.
I assume these two would go to the two small, unlabeled and asymmetrically located SMD pads on the back of the board near the JFETs/cascode elements. Correct?
- You might want to add the "-Y"-suffix to the "MFG PN" column for the power MOSFETs.
Old 9th December 2012, 04:40 PM   #234
NicMac's Avatar
About 7.9 mA
Old 9th December 2012, 06:11 PM   #235
Then I expect you to get 6~7mA bias rather than 4.4mA.
You could have checked by just measuring the Id of each JFET with 10R degen.
That should be roughly your bias for the fist stage.
Patrick
xen-audio.com
Old 9th December 2012, 07:10 PM   #236
NicMac's Avatar
I could indeed have, especially if I knew that I ought to.
Is there a "sweet-spot" to aim for?
Should I just leave it or would I be better of fixing the problem in some way?
I guess I could easily lower the 11R triplets with some parallel (matched) resistance (mounted on the underside of the PCB), but I'm not sure if this is the way to go.
Anybody else measured these currents?
Old 9th December 2012, 07:59 PM   #237
fitzfish is offline fitzfish  United States
Hi Nick,
About 7.9 mA
The Idss of the sets I put together came in at 6.8mA for the K170s and 7.8mA for the J74s. The front end current measured for these is ~4.8mA in circuit. See the chart here for ballpark targets for Idss and Rdegen based on calculations from the datasheets.
If your J74s and K170s in each set are the same Idss I don't think you will want to use the 5R1 degen resistor that is mounted on the bottom of the amp board. Substitute a zero ohm or small wire there. This resistor serves to more closely match the gain curves of the J74s to that of the K170s but only when the J74s are selected with higher Idss as described in the post/chart linked above.
Dave
Old 9th December 2012, 08:17 PM   #238
NicMac's Avatar
My 7.9 mA device Idss is for both the K170, and the J74 (after degeneration with appropriate Rdeg).
You get 4.8 mA front-end bias with 6.8 mA device Idss, while I get 4.4 mA with 7.9 mA device Idss. Any explanations come to mind
Anyway, maybe my 4.4 mA front-end bias is just fine.... I just don't know what to go for.
Old 9th December 2012, 08:56 PM   #239
Inputs to the AMP/JFETs grounded? Otherwise I don't know. Best match for me was using 4R for degen - so my JFETs were lower than datasheet typical numbers for gain. What are you using for Rdegen and do all four corners measure the same bias current?
Dave
Old 9th December 2012, 09:11 PM   #240
NicMac's Avatar
Inputs are grounded. I'm using four different Rdeg's for the four J74's
These are the measured values (mV drop over the 11R blocks) of the eight corners:
L: 48.1, 49.1, 47.8, 49.8
R: 48.1, 49.2, 48.0, 49.0
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
