F5X -- the EUVL Approach - The Build Thread - Page 20 - diyAudio
Old 26th November 2012, 09:51 AM   #191
JBdV is offline JBdV  Netherlands
Filing the 4 holes into one long slot by hand is probably pretty easy as well
Old 26th November 2012, 10:33 AM   #192
EUVL is offline EUVL  Europe
Yes, or use a dremel just to chamfer one side of the holes.
They don't need to be deep (the chamfer), just 2 or 3 mm at most.
So technically not a real problem. And you also don't see them afterwards.
Patrick
xen-audio.com
Old 26th November 2012, 01:17 PM   #193
MarkLai is offline MarkLai  Hong Kong
Try to filing the 3 pcb mounting holes by 2mm side way!
Mark
Old 26th November 2012, 01:30 PM   #194
No, that will not work.
Becuase it is the centre distance between the terminal blocks that is incorrect.
You need to file the 8 holes meant for the terminal blocks.
This will of course be correct for Batch 2.
Patrick
xen-audio.com
Old 26th November 2012, 03:28 PM   #195
Horio is offline Horio  United States
Horio's Avatar
I don't have a countersink tool, but I can use a slightly larger drill bit to chamfer the hole. I'll try it tonight and see how it works. The hole locations are only slightly off, so it should only require a little modification to get the boards to fit. Like you said, the holes will be completely concealed by the boards anyway.
Old 26th November 2012, 10:31 PM   #196
Patrick how far off are batch 2 pcbs?
If the wait isn’t that long I may hold off for the correction.
Old 27th November 2012, 03:41 AM   #197
Greg, get yourself a countersink tool.
They are not expensive, and will do a much better job than a larger drill size.
Batch 2 PCBs
We have no real need to order them now, as the matching will be done by April.
But they will be done by us, as opposed to your which are a GB made in the USA.
So they will not look the same in appearance (e.g. blue solder mask as opposed to black ?).
If you want perfection then you need to have a completely new set.
Faster we can arrange those would be say some time January.
Patrick
xen-audio.com
Old 27th November 2012, 04:34 AM   #198
Horio's Avatar
I tried the larger drill bit technique, and as you predicted it didn't do a very good job. Like you said, a countersink tool would do a much better job. Trying out the drill bit did make me realize that the required countersink is going need to be very large. A very large countersink is going to be required to provide a cavity deep enough and far enough out to allow for the pints to fit. In fact the outside edge of the countersink may reach the edge of the teflon bracket. I'm starting to think that the best solution is to either mill a single long slot for the pins, or use a spacer to raise the boards off the teflon block by a few millimeters.
I can still try the countersink method with the proper tool, but I won't have the time to pick up the tool until this weekend.
Old 27th November 2012, 09:14 AM   #199
Needle file to the one edge that fouls the soldered lead.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th November 2012, 10:07 AM   #200
Long slot 3mm deep from both ends or through is probably the best solution, but requires a milling machine.
As said, those in Europe can send to me. The rest would have to send t Mark. Or Greg has access ?
Needle files or dremel is another. Not as perfect but fully functional.
Forget the countersunk for now.
New PCB is the easiest, but also most expensive. Also Jan already soldered, so no option for him.
Since the PCBs are from a GB I can only accept partial responsibility (that I did not spot the mistake in the Gerber).
But spotting the difference between 25mm & 28mm by naked eye is a bit beyond the average visual capability.
So we'll have to charge say 50% cost (cap boards only) plus postage if you want new PCBs, unfortunately.
Patrick
xen-audio.com
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright 1999-2017 diyAudio
