#151 |
Although I should allow you to enjoy your achievements I can't help to show where I am....
In blue the calculated Idss/Yfs of the 2SJ74 after 5R1 degeneration. |
#152 |
Nice figure.
Shows clearly that my guestimation 5R1 is near spot on !!!! ![]() Patrick
xen-audio.com |
#153 |
Of course your 5R1 value was chosen for a reason like most things you do
![]() For my FETs I actually find 5R6 and 6R2 to be a bit better. As computing cost little I in the end actually used 7 different Rdeg (4R3, 4R7, 5R1, 5R6, 6R2, 6R8 and 7R2) to generate a virtual set of 2723 degenerated 2SJ74's (see figure) and used these for matching. With those I obtained 42 NNNNPPPP-sets with 0.5% tolerance for both Idss and Yfs. This is a yield of about 43% for the 2SJ74. Of course there is the downside that each 2SJ74 will need a different Rdeg. But as a DIY'er I can live with this minor logistic complication. Obviously Oneclock has measured matches while mine are calculated and should to be verified experimentally. I nevertheless trust the practical validity of the equations some kind person provided me with ![]() Where is that F5X Pre? ![]() Cheers, Nic P.S. Note how increasing Rdeg pushes both Idss and Yfs down posing a limit to what can be achieved in terms of matching. Using 100 different Rdeg's values would in fact not increase yield notably. Many 2SJ74 will never match because they have to low Idss. |
#154 |
On my table, waiting to be built. > Many 2SJ74 will never match because they have to low Idss. Get some 2SK170GRs. ![]() Patrick
xen-audio.com |
#155 |
I didn't think about that. You never run out of solutions do you
#156 |
Should I ?
:-) D. |
#157 |
These are all old problems known years ago, so are the solutions.
Nothing exciting. ![]() Patrick
xen-audio.com |
#158 |
Right place - right time
![]() Go ahead. Nic |
#159 |
Not excited. Just learning from others experience.
#160 | |
D. |
| F5X -- the EUVL Approach | EUVL | Pass Labs | 812 | 14th May 2013 02:25 PM |
| Potential EUVL F5X designed case user distribution check | pchw | Group Buys | 1004 | 27th February 2013 03:32 PM |
| GB 2SK3497/2SJ618 for EUVL F5X or other projects | pchw | Group Buys | 266 | 8th April 2012 06:05 PM |
| [B]PRP resistor group buy for the EUVL F5X build[/B] | NicMac | Group Buys | 70 | 4th February 2012 04:20 PM |
| New Saburo Build thread | Wha' DIYa know? | Full Range | 94 | 17th October 2010 04:49 PM |
