F5X -- the EUVL Approach - The Build Thread
Old 11th October 2016, 01:02 AM   #1011
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Hi Markus,
Do you think these white chopping boards will do?
Old 11th October 2016, 07:34 AM   #1012
EUVL is offline EUVL  Europe
Too thick.
POM is commonly known as acetal, or Delrin.
Should be widely available.
Patrick
xen-audio.com
Old 11th October 2016, 08:22 PM   #1013
Triodethom is offline Triodethom  United States
Triodethom's Avatar
ebay or local suppliers delrin or pom is very widely avalible in sheets and rods . Easy to work but can be slippery and hard to hold. teflon is also available but at higher cost.
Old 7th December 2016, 07:57 AM   #1014
samoloko is offline samoloko  Bulgaria
I would like to use Hifi 2000 case Including 2 x 200 mm heatsinks per side
https://www.modushop.biz/site/index....product_id=218
what do you think about alternative placement of parts In order to get better heat transfer - pcb Is mounted between two heatsink and all devices are placed at one row using extension wires from pcb
Old 7th December 2016, 08:46 PM   #1015
Markus is offline Markus  Germany
Considering a bigger housing and bigger heat sinks is certainly not a bad idea. The first for ease of integration and extendability and the second for lower operational temperature.
If you could fit besides the amp boards also the associated rectifiers and regulators to outer heat sinks then integration and testing will become much easier since you have everything needed to operate one channel besides the transformer mounted to one heat sink. Hence you could do all the wiring and pre-integration tests outside.
I will continue my bottle ship hobby with the original housing ...
First listening test were not to too bad BTW.
Cheers
Markus
Old 7th December 2016, 09:13 PM   #1016
Default Stripping off enamel insulation from trafo wires
Since we had to shorten the transformator secondary wires we had to strip off the enamel insulation but this turned out to be a very time consuming task ( I have 2 amp units, 2 transformers each, 4 secondaries each, 3 wires each, 2 ends each = 96 wire ends) and the results were also not always of the desired quality. If there are residuals of enamel which are hard to see with bare eyes the solder does not wet properly.
I looked around for appropriate tools but the professional tools with a motorized rotating blade cost more than 500.
So I invented my own simple and cheap tool. The idea is to cut a thread on the copper wire and herewith to remove the enamel. I use a M1.6 die for stripping off a wire with 1.55mm diameter. This works perfect, one wire is stripped off within less than half a minute and the solder wetting test show very good results.
Cheers
Markus
Old 8th December 2016, 01:18 AM   #1017
1511120 KNIPEX - Abisolierer | TME Germany GmbH - Electronic components
9 Euros, made in Germany. Available also from Buerklin.
I know German are used to large houses.
You can always put the entire PSU external.
Gets rid of Tx tray fields, leaves you plenty of space inside the amp.
Patrick
xen-audio.com
Old 8th December 2016, 06:14 AM   #1018
Patrick,
would you please comment post #1014
Old 8th December 2016, 06:20 AM   #1019
The approach for case design for a Class A power amplifier has been described in full detail in my article at Linear Audio, using the F5X as an example.
I have an arrangement with Jan Didden to make it available for free download.
You may wish to use that as a reference for your own build.
Patrick
xen-audio.com
Old 8th December 2016, 07:43 AM   #1020
Patrick,
thank you for reply
I read your article but there Is one heatsink for side not 2
In that regard do you see drawbacks from placing devices In one raw spaced equally on two heatsinks
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 877 20th October 2015 07:48 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
