I just got the boards for the BOSOZ. Am I missing out by not trying one of the others? Or is it a matter of taste between these 3 preamps.
What's your opinion? Thanks, Vince |
#2 |
Since you have the BOSOZ boards already go ahead and build it...
you won't be let down, it's a fine sounding pre. ![]() don't go second guessing yourself, life's to short. |
#3 |
I agree Moe, (i'm building the BoSoZ too)
Vince, if you want to do some tweaking you could always "X" the BoSoZ. (search for Henrik on this forum and you'll find the schematic) Good luck with building... ps watch out for the size of heatsinks in the power supply. If you use the power board, the space on it is too small. My heatsinks reach allmost boiling temperatures Grtz, Nick |
#4 |
agreed: as to the power supply heatsinks...
i had to modify my power supply PCB to be able to handle bigger heatsinks for the regulating fets. It wasn't that hard to do, but seemed the prudent thing to do. |
#5 |
My BZLS (or BOSOZ) PCB is on the way. Can anyone who has built one share how you use your level control? The original design can use either on the input side or on the output side!
One diyer told me he put on both input and output, but he did not see any benefit with it and suggest me use the input side. Any thought of this? Also, do I really need to use the expensive 4 decks attenuator (like the DACT CT2-4) for a balanced stereo output. What's the cheaper solution, yet provide reasonable good sound? Thanks Thomas |
#6 |
Put the control on the output, so noise is also lowered when you adjust for the volume.
#7 | |
Custom Title
vdi- bad idea. You wind up effectively raising the output impedance severely. That's why volume controls are put before the circuit in these things.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#8 |
That's not what I remember reading in NP's artical.
Then again I could be wrong. |
#9 | |
#10 |
have a look balanced volume control
| BoSoZ & Aleph caps- need help | xsnailx | Pass Labs | 24 | 4th October 2003 12:18 PM |
| ALEPH P 1.7 & BOSOZ PS PCBs | kristijan-k | Swap Meet | 7 | 12th March 2003 10:26 PM |
| BoSoZ & Aleph caps- need help | xsnailx | Multi-Way | 1 | 5th February 2003 08:29 PM |
| Coupling Bosoz to Aleph cap question? | protos | Pass Labs | 4 | 12th December 2002 06:07 PM |
| Aleph P or BOSOZ variant | stefan | Pass Labs | 14 | 10th September 2002 09:27 PM |
| Page generated in 0.09875 seconds (77.85% PHP - 22.15% MySQL) with 10 queries |
