Aleph P 1.7 - distortion - Page 2 - diyAudio
Old 6th March 2012, 03:43 PM   #11
generg is online now generg  Germany
generg's Avatar
I had the same effect (Kristian boards) and did not find the reason ....... Also at that time I had no oscilloscope or sound card solution.....
At I did what Zen Mod said I simply kept the 10k in the signal path.......
and the First Wtt is......a really First Class PSS Idea
Old 6th March 2012, 03:48 PM   #12
KatieandDad's Avatar
You will see clipping with the cheapest of oscilloscopes, even the $10 USB E-Bay specials.
Old 6th March 2012, 04:49 PM   #13
@AudioSan
can you give some details about the caps you used in your setup? I also want to use these boards, but I can`t find caps which will fit in pcb and are really good. to know where to buy will be good too ;-)
greetings Arno
Old 6th March 2012, 05:07 PM   #14
Send a message via Yahoo to Th3 uN1Qu3
20MHz will work just fine for any audio application.
"Audio grade" components simply means that they failed at a more critical job.
Old 6th March 2012, 05:19 PM   #15
generg's Avatar
Originally Posted by julius20 View Post
@AudioSan
greetings Arno
Hi Arno,
I am not AudioSan...
my experience
Elna Silmic 50V/220uF bypassed by 100nF, that is the setup I returned to, after trying Obbligato, Blackgate, Erol, Cornel Dublier.... every cap had its own advantages, but overall I preferred the Silmics.....
Old 6th March 2012, 06:25 PM   #16
@AudioSan
greetings Arno
what caps? the red ones? they are panasonic. i got them from mouser.
10uF 250V i think. its a long time ago
Old 6th March 2012, 07:29 PM   #17
at houser i couldn`t find it, but at digikey
Old 12th March 2012, 11:03 AM   #18
Mfly is offline Mfly  Netherlands
Well, thank you all for your input.
Unfortunately I was listening last night on the single ended inputs and after about 3 hours listening time the distortion appeared sometimes (even with the 10k resistors on the input).
It sounds like the sound is transformed into high frequency static. The 9610's also get quite hot (they are on small heatsinks). So this seems like oscillation from what I have read so far...
There are 680pF capacitors between the collector and emitter of the ZTX550's. Would adding 1nF capacitors between the base and collector as described here be a possible solution?:
preamplifier Pass X2.0/1
Or should I be buying a scope (which isn't a bad idea anyway) and do a more thorough analysis before I start adding components?
Old 12th March 2012, 11:20 AM   #19
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
make this , connect it to output and crank it (volume ) all the way up (disconnect amp before )
and - buy a scope
if you have oscillation , LED will lit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th March 2012, 11:30 AM   #20
generg's Avatar
I just remember.....
I put the same 680pF on the lower side in the same place to the ZTX450 and the osci was gone....
But I do not know if this had any disadvantages, can anybody comment?
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
High Distortion on Aleph 5 Jaac Pass Labs 12 2nd June 2007 02:29 AM
Waveform distortion on Aleph 30! panos29 Pass Labs 30 26th May 2003 09:40 AM
Copyright 1999-2017 diyAudio
