I know there has been lots of discussion on the various Alephs.
Here's my dilemma: I was planning on building a pair of 1.2's. I already have the metal and most of the parts for the project. But, now I'm wondering if it wouldn't make more sense to build an Aleph 2 in the same chassis using a large transformer, possibly additional fets and really crank the bias since the chassis will be able to dissipate much more heat than a standard Aleph 2 chassis... I've read repeatedly that higher bias sounds better. The question that comes to mind - is there a point of diminishing return? Which is better, high output wattage or much higher bias? Opinions? The load will be a pair of Apogees... Thanks,
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin |
#2 |
If u intend to drive Diva's in high spl's in a larger than average listening room, I think u need 4 Aleph 1.2's.
If it's about Scintilla's, Lord knows. And if you have Duetta's, I think 4 Aleph 2's can do the job. Good luck, Nick |
#3 |
You need the current for you’re the Apogee speakers. I use to own a pair of one ohm Scintilla's, that speaker would eat the output of my Threshold amps, so I got a Krell it had more current capability, which worked fine with that load.
Therefore, I would go with the amp that has the most current capability and that is the Aleph 1.2. Having said that, I believe if you lower the source resistors to 1 ohm instead 1.5 that would lower the output impedance of the amp making it an easer to drive the load. Also, should consider look at lowering the value of all those .47 ohm output resistors that are in series with the speakers. Making these changes might help am Aleph 2 work with the Apogee speakers. Of course this all depend on which Apogee speakers you have, they all like high current amps. So my Aleph build is in the same state as yours, however I no longer have my Apogee speakers. Maybe Nelson might respond to the changes in the output stage of the Aleph.
Jim W. |
#4 | |
The one and only
Aleph 2 with the heat sinks and bias wattage of the 1.2 |
#5 | |
diyAudio Retiree
Say........ Just how many shares do you have of International Rectifier? With all respect, Fred |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.08698 seconds (80.45% PHP - 19.55% MySQL) with 10 queries |
