#171 |
LabJr,
Take a look at the link about the discontinuation of the parts. If we can get a replacement for the 19n20C, and retain the 12P, which Nelson highlights, then we have gained ground over the IRF parts, possibly. I have heard 3 different sets of transistors in my BA3. For me it goes laterals, Fairchild, IRF in order of sound. Laterals just have something special in their tone, or they and Farichild would be tied. This is all very subjective opinion and you are correct though, the IRF's will work just fine. They do have a known issue in the P channel part, as pointed out by FLG in the Hansen thread, but this may be of no consequence. I was just trying to stick to what was recommended as best as possible.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#172 |
you guys want to add mur3020 to GB list? over 1000, we save $1 per diode.
#173 |
That's a great idea. Count me in!
![]() Edit - Looking at Mouser and Digi-Key, it looks to be a very, very good deal to do this.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - - Pass F4 Last edited by 6L6; 14th April 2012 at 08:06 PM. |
#174 |
Totally dependent on turnout. Its on spreadsheet.
#175 |
If we get 500 of the diodes, we are talking $1.50/piece. quick signup is important because there is a 9 wk delay in maunfacturing.
#176 |
#177 |
Interesting diodes for power supply. Are they soft recovery, low noise?
#178 |
Soft revovery for sure. Just know that Nelson uses them in the F5T, so most people will need them. I would assume they are low noise considering the F5T's performance.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! Last edited by buzzforb; 15th April 2012 at 05:58 PM. |
#179 |
Would these be a drop-in replacement for the BA2?
Thanks Dave |
#180 |
Meaning the mosfets, yes. They are actually Nelsons chosen parts . They would need to adjusted as their Vgs vs Ids is different. We are looking at the 16n25c as a replacement for 19n25c.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! Last edited by buzzforb; 15th April 2012 at 06:24 PM. |
| fairchild find? | tinkerbell | Solid State | 9 | 28th April 2012 02:26 AM |
| Fairchild transistors | GregH2 | Parts | 1 | 28th August 2011 02:53 AM |
| Fairchild Reverbertron 2???? | Newpaltzwonder | Parts | 4 | 27th May 2011 01:13 PM |
| Fairchild FJA4310 | jgray | Solid State | 7 | 11th November 2010 05:29 PM |
| Fairchild direct | pdul | Parts | 1 | 5th January 2010 04:37 PM |
