Fairchild interest.
Fairchild interest.
Old 7th April 2012, 02:42 PM   #161
buzzforb is offline buzzforb  United States
buzzforb's Avatar
To all GB members. I am going to give it one more week on the 19n20c and 19n20 parts, and then i think it will be time to talk about alternatives. The 19n20C parts are probably not going to happen, I have seen only fakes. THe standard 19n20 parts may be more likely, but kind of in the same scenario. I have found what may be a better match to the 19n20C. It is part 16n25C,also EOL. Still available to some extent, although i dont know if it is quantity great anought o meet demand. I think we need to decide which way to go with this thing. If either of these EOL life parts cannot be sourced, you have nothing but new parts. Although Nelson seems to accentuate the P parts in the article, all the newer parts available for the N channels have much greater Yfs or input capacitance compared to the 19n20C. We can discuss alternatives in a new thread. If no reasonable candidate is chosen, the best option is to go with the FQP version of the parts.
...Shape the sound , Man!
Old 7th April 2012, 02:46 PM   #162
6L6 is offline 6L6  United States
6L6's Avatar
Fairchild interest.
I am still in for whatever genuine parts you can source.
Do your best. It's certainly not your fault. We are all victims of the counterfeiters.
Old 8th April 2012, 01:15 AM   #163
bkdog is offline bkdog
Fairchild interest.
i'm still in too - many thanks for all of your efforts Buzzforb! These parts are difficult to source.
Old 8th April 2012, 01:25 PM   #164
albertNL is offline albertNL  Australia
Fairchild interest.
Thanks for your efforts, buzzforb. I will check to see how you go.
Old 9th April 2012, 03:35 PM   #165
buzzforb's Avatar
I am almost 100% sure that i have secured what i believe to be the best alternative to the 19n20C. I have one more lead on the original, but if it doesn't pan out, I would suggest FQA16n25C. I will provide links to both datasheets and I believe you will see that they are almost identical in performance.
19n20C
http://media.digikey.com/pdf/Data%20.../FQA19N20C.pdf
16n25C
http://media.digikey.com/pdf/Data%20.../FQA16N25C.pdf
Old 10th April 2012, 01:18 PM   #166
buzzforb's Avatar
I can get FaArichild orginal FQA16n25C parts in sealed boxes. I have some samples on the way and will provide a comparison between it and the orginal 19n20c part. If all looks good, then i will put it into an F5T and try to get some distortion numbers to compare to the article. I also will try to contact all GB members and inform them of what is happening.
Old 12th April 2012, 05:00 PM   #167
studeb is offline studeb  United States
studeb's Avatar
same post as in other thread.
i think the best is to try the 16n25 compare it with the "real deal" and see if you can tell them apart by ear or otherwise.
Could the oscillating "fakes" be tamed, they could have been rejects
Old 12th April 2012, 05:27 PM   #168
buzzforb's Avatar
Rejects or not, I am not interested. As for the sound difference, in the F5T article, Nelson shows 19n20 rather than 19n20C, which he sates in the thread linked erlier, were his chosen parts for F5 and F4. THe 19n20 shows greater differences over the 12n25c, when comp[aring to the 19n20c. It is possible the article contains a typo and this is all moot. Unless something is unusual about how the part performs, I dont think most people would ever know a different part had been used. Differences between brands, like irf249/9240 vs Fairchilds is nuanced and subtle, and if you had not heard one or the other, you wold still be getting the main sound that characterizes the F5.
Old 13th April 2012, 02:13 PM   #169
Horio is offline Horio  United States
Horio's Avatar
Definitely give the 16n25 parts a shot, see how they measure and let us know the results. The spec sheet looks promising.
Old 13th April 2012, 02:57 PM   #170
labjr is offline labjr  United States
Why not just use IRF parts then?
Fairchild interest.Hide this!Advertise here!
fairchild find? tinkerbell Solid State 9 28th April 2012 02:26 AM
Fairchild transistors GregH2 Parts 1 28th August 2011 02:53 AM
Fairchild Reverbertron 2???? Newpaltzwonder Parts 4 27th May 2011 01:13 PM
Fairchild FJA4310 jgray Solid State 7 11th November 2010 05:29 PM
Fairchild direct pdul Parts 1 5th January 2010 04:37 PM
