switching power supply.. can't get -24v?
Old 20th February 2012, 11:54 AM   #1
BScorner is offline BScorner
Default switching power supply.. can't get -24v?
I am fairly new to this.
Can anyone help me setup a switch mode power supply to test my pcb with. I have everything populated but when I go to hook it up...the way i think is correct i can't seem to get -24 volts? I seem to get +24 fine.
Where do i connect the ground wires on the pcb directly to psu? pcb ground to chassis.
any help is appreciated
Old 20th February 2012, 02:12 PM   #2
6L6 is offline 6L6  United States
6L6's Avatar
Mr. Bulls Hit,
Is it a single SMPS? I doubt you can make a bipolar supply with it.
Also, it would be of great help to know what you are building...
Old 20th February 2012, 02:29 PM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
pics , pretty please
presuming that your switching PSU is +24Vdc , you'll need two of them for bipolar supply
in stacked arrangement
but , clarify , so we can help
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th February 2012, 04:02 PM   #4
Greetings.
I will try to attach photos... see attached
power supply is UAW250S:
http://www.cosel.co.jp/en/products/pdf/SFE_UAW.pdf
It is aleph J pcb I want to start up
Old 20th February 2012, 04:16 PM   #5
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
It's only a single 24V supply so you would need two of them to provide + and - supplies.
I note you already have two of them, I presume you have one for each amp.
I have to assume that the outputs are electrically isolated from each other.
Try connecting V+ of one to V- of the other and use this common connection for 0V. Then use the unused V- and V+ as your -24V and +24V supplies.
Old 20th February 2012, 04:20 PM   #6
Zen Mod's Avatar
you need to stack two of them to have bipolar PSU
+V of first is +24v
-V of second is -24V
connect bridge between -V of first and +V of second , and that's system audio GND
Old 20th February 2012, 04:23 PM   #7
There's an echo in here.
Old 20th February 2012, 04:24 PM   #8
Thanks for everyones replies.
I will look for a single dual power supply.. I have two of these 1u power supply but i do not want to use two because it will be too big for my chassis unless i mount into seperate chassis like in the photo it now looks big and ugly LoL
Again thanks I will try Kate and Dad's suggestion first.
Old 20th February 2012, 04:28 PM   #9
boyofwax is offline boyofwax  Netherlands
boyofwax's Avatar
According to the datasheet these SMPS's are single output.
Your last picture shows FG (frame ground) connected aswell as + and -.
To hook up the right way is to connect the + from one PS unit to the - of the other. This connection will be GND for the amplifier! Then take + from one and - from the other unit (those that were NOT used to connect GND).
Pls check the SMPS frame if it is connected to the -. If this is not the case then proceed. The FG terminals connect to earth.
If the case is connected to - then one PS must be mounted insulated.
Old 20th February 2012, 04:28 PM   #10
I also have another question as for RCA input... do I bridge -In to ground?
Thanks again guys not too much BS around here today
switching power supply.. can't get -24v?Hide this!Advertise here!
need a smallish 24v 5A power supply .. onis_uk Power Supplies 3 29th August 2010 03:12 PM
Which 24v dc power supply for T amp? dublin78 Power Supplies 1 16th May 2010 08:45 AM
need help in building 24v power supply milen007 Parts 10 11th September 2008 05:11 AM
24V AC power supply for MAX. L.Arve Power Supplies 1 26th March 2008 01:43 AM
Copyright ©1999-2017 diyAudio
