#911 |
zoe - to clarify, (which buzz was touching on) do you mean 24v rails or a 24v transformer?
An 18v+18v (alternatively 36v centertapped) transformer will get you 24v rails. a 24+24v (or 48v centertapped) transformer will get you 32v rails. |
#912 |
Yes that's it thank you 6L6 if I allow the angle to go under the trany attach to the bottom this should save room, still have to make sure that it doesn't interfere with the amp boards or make it hum.
be good zoe |
#913 |
I think I would have been fine with a smaller transformer say down to 600va dual secondary.It was just a little more for the bigger one. I read that multiplying the rail v by .75 will approximate the secondary voltage needed.There is different ways to accomplish the same things.
be good zoe |
#914 |
here you can see 11" wide x 50" deep bottom with a 1000VA transformer.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#915 |
Zoe,
I'm thinking of using that same transformer, 1000VA which gives 4 pairs of 25V secondaries. The other option for Antek is a 600VA 2pair 28V. I'm also thinking of mounting the toroid vertically in the front. I found a good picture of an example on how to do that (very nice build photo from someone at the forum here). How much power would the F5Tv2 make with that Antek toroid? Well, 25V * 1.4 = 35V DC and 25V * 1.3 = 32.5V DC --> Is my understanding correct? It seems like this is right where it needs to be, correct? Last edited by nrg2009; 9th January 2013 at 01:43 PM. Reason: addition |
#916 |
2x25V sec transformers fits v2 very good.
#917 |
not politcally affiliated
NRG, the 1000VA unit, just take the same + wires and solder or whatnot together, and same with -, and you got a 1000VA tranny with 500VA each side. Double current ya!
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#918 |
#919 |
Another EASY way to support mounting a transformer on end is to use "L" shaped shelf bracket. This is a picture of a construction metal angle brace. Simpson Strong-Tie.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. Last edited by Renron; 9th January 2013 at 03:12 PM. Reason: Removed incorrect example. Sorry..... |
| F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2115 | 11th May 2013 08:18 PM |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| B1 builders thread | Bas Horneman | Pass Labs | 688 | 27th February 2013 11:15 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
