F5 Turbo Builders Thread
Old 9th January 2013, 12:17 AM   #901
zoe is offline zoe  United States
I bought the Antek an10425 1000va trany.
I am getting tea's ps boards as I'm on Buzz's gb list.
Can I stack the caps.
Buzz why would you want a bigger chassis?
be good
zoe
Old 9th January 2013, 12:23 AM   #902
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I like space. It helps in tuning, testing and setting. My build uses a smaller toroid, PSU with almost exact board dimensions as TeaBag PSU, and 10" is tight with boards mounted to 6" tall sinks. Its clean and think I have pics a couple pages back. Ill find it.
i lied. Cant find it. Been posted coulpleof times.
...Shape the sound , Man!
Old 9th January 2013, 12:46 AM   #903
Makes sense. I have 7" top to bottom inside. I wounder if I can install my transformer vertically in the front of the box. The things already big whats a few more inches if I make it 20" wide that will give me 12x7x17" inside. I got to get my transformer specs.
Better to big then to tight but what a beast. Hope the wife doesn't blow a gasket. I already have to many toys.
be good
zoe
Old 9th January 2013, 12:47 AM   #904
6L6 is offline 6L6  United States
6L6's Avatar
What's the consensus on minimum transformer for a F5T v2? 24v+24v 600VA?
Using the rule of thumb of 6x the amp's total output into 8ohm, that would fit the bill.
zoe - (which happens to be the name of the dog in my Avatar... ) I agree with buzz, bigger is much more convienent for construction and tuning. But small has it's attractions as well. As usual, everything is a tradeoff.
Old 9th January 2013, 12:53 AM   #905
Can you make a v2 with 24 volt rails?
be good
zoe
Old 9th January 2013, 12:59 AM   #906
6L6's Avatar
Yes, but it wouldn't be a 50WPC amp.
Old 9th January 2013, 01:06 AM   #907
buzzforb's Avatar
I have 400VA, but I get very small hum with ear to speaker. I assume its from undersized trafo, as all my other amps are dead silent, but none push the transformer this much.
Zoe,
Just lay it out and see how it all works. The 24V is secondary voltage, which needs to be multiplied by 1.41(1.3 for Class A) to get rail voltage.
Old 9th January 2013, 01:31 AM   #908
Renron is offline Renron  United States
Renron's Avatar
TX wise, I'm planning a neutered V3 with 800Va w/ 2x25 secondaries. TX~6.5" wide 3.5" tall
neutered = lower voltage and lower bias.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 9th January 2013, 01:42 AM   #909
The one I ordered is the same size. any ideas how to attach vertically in front without drilling thru faceplate
be good
zoe
Old 9th January 2013, 02:01 AM   #910
6L6's Avatar
Angle bracket for holding transformer vertically. I'm not sure where to get them, as I have pulled them from surplus, but they do exist.
Or just a big piece of angle iron (aluminum)
Drilling a blind hole in the faceplate will not hold up the transformer.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
