Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#861 |
2x30 VAC of course, sorry...
![]() ok, that sounds nice, AudioSan! would 4ohm speakers be a Big Problem? best regards, Matthias |
#862 |
4ohm will not give you much class A power. then you are down to 20W class A. and about 170W class A/B. i would use a little bigger transformer for that. but it all depends on your volume
#863 |
Official Court Jester
agree with Trondheim Boy
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#864 |
we agree on alot this days
#865 |
Wow!! AudioSan brings in the heavy metal!! Wow, that's a lot of heatsinks.. You better upgrade your electrical connections to your house!
#866 |
#867 |
ZM. a question. i have pr now R5/6 at 1Kohm, and 7.1mA J-fets(i forgot to calculate a reise of the resistance)
i can solder in some 2.2Kohm resistors. or i have another set of 7.1mA J-fets i can solder in, to dobble up the J-fets. what would you do? i don't know if 2.2K will be enough for 7.1mA fets. but with dual 7.1mA fets, 1Kohm chould be enough? right? |
#868 |
considering that you're going to Turbo (driving 3 pairs ? yes ?) , I would toss another pair of small Toshiba critters in
in any case - metal film resistors are pennies each , so every time when you buy them , buy triple your needs ....... and not just values you need in a moment - then you'll have them when you need them I'm hearing differences between resistors only in really low level circuits - for power stages you're always more than good with cheapest MF resistors those already are of decent industrial quality , and that's serious thing
#869 |
acctualy 4 pairs
![]() ![]() ![]() but for this case, i think i go with dual J-fets. that was my plan from the beginning becouse of the 4 pairs outputs. it can be a little on the limit for 1 pair of J-fets. i use Dale CMF60 all the way on this ones. exept the 3W's ofcourse. and R2 (forgot to order 47.5Kohm resistors) ![]() Last edited by AudioSan; 7th January 2013 at 10:10 PM. |
#870 |
amp layout. and diodes soldered in. only outputs and some wireing left until first start up. also soldered in another pair of J-fets.
Thread | Thread Starter | Forum | Replies | Last Post |
B1 builders thread | Bas Horneman | Pass Labs | 728 | 12th March 2018 06:45 PM |
F5 Turbo is posted | Nelson Pass | Pass Labs | 638 | 27th December 2017 06:12 PM |
F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2404 | 8th October 2017 07:14 PM |
F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
New To Site? | Need Help? |
