F5 Turbo Builders Thread
Old 6th January 2013, 09:47 PM   #831
AudioSan is offline AudioSan  Norway
less bias pr device. or higher total bias.
sonics will change a tiny bit. but for the better or worse, that depends on who's listening
Old 6th January 2013, 09:58 PM   #832
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Hi Guys,
I got these in the mail yesterday and have been at them mostly since,
Check them over,
I am planing on 32 volt rails,around 15 volts for cascode,
I couldn't find the link about the link,Link to gnd?
Q5 and Q6 are correct with the silk ,are they backwards ?need to be turned around?
N out and P out switched on signal board,
any known issues?
I decide it was best to ask instead of smoking,,,,,,,,,
Thanks alot,
NoSmoking.........
Old 6th January 2013, 10:01 PM   #833
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by N-Brock View Post
R5 has 4.22 volts across it. R6 has 4.55 V.
34 volt rails. No cascade going on.
I really appreciate the effort.
What V across source resistors of mosfets. Also, measure across gate and source of mosfets directly. 34V is pushing the Jfets id they are high Idss, but they are alive.
...Shape the sound , Man!
Old 6th January 2013, 10:06 PM   #834
buzzforb's Avatar
Originally Posted by noSmoking View Post
Hi Guys,
Check them over,
any known issues?
Thanks alot,
NoSmoking.........
Power up FE first and set drop across r5,r6 to 3.5V using P1 and P2. THis will allow you to figure out which way to turn the posts in order to adjust them. You will be starting at similar Vgs and will have solid footing for hooking up mosfets and firing them up.
Old 6th January 2013, 10:06 PM   #835
Q5/Q6 is correct oriented on those boards. N-ch and P-ch is also correct.
Hi Guys,
Check them over,
any known issues?
Thanks alot,
NoSmoking.........
Old 6th January 2013, 10:07 PM   #836
buzzforb's Avatar
Oh, that sucks. All ok on your front.
Old 6th January 2013, 10:08 PM   #837
N Brock is offline N Brock  United States
N Brock's Avatar
P-ch
Source resistors: 136 mV
G-S: 4.06 V
N-ch
Source res: 139 mV
G-S: -4.38 V
Old 6th January 2013, 10:11 PM   #838
what sucks?
well. got my sinks cut tonight. so there will be some drilling and tapping tomorrow and if i'm lucky. there will be a power up
Old 6th January 2013, 10:19 PM   #839
buzzforb's Avatar
P-ch
G-S: 4.06 V
N-ch
Source res: 139 mV
G-S: -4.38 V
If your maxed out on p1 and p2, then simply increase R5 and R6. You hove lower Idss Jfets and you just need higher load resistor, as AudioSan suggested, to bring up VGS for the mosfets. All is perfectly fine.
Old 6th January 2013, 10:20 PM   #840
buzzforb's Avatar
what sucks?
Thought maybe you were suggesting possible routing error on output fets in beta board.
BTW, you may know this, but power drill with clutch set low, and some WD40 is excellent speedy tapping method.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
